| REW Forum New member and RT60 with REWDiscuss New member and RT60 with REW in the Equalization | Calibration forum; New member and RT60 with REW Hi, i'm a new member here and i'm going to use RoomEQ wizard together with a Behringer ECM8000 microphone and ... |
Views: 403 - Replies: 11
| New member and RT60 with REW Hi, i'm a new member here and i'm going to use RoomEQ wizard together with a Behringer ECM8000 microphone and an EMI 6|2 soundboard (usb 2.0), but i just need to get the RT60 of my room without setting EQ to compensate etc. etc... I've just downloaded and read the REW HELP but i've seen that in the "getting started" they always refer to EQ, processors etc... but how should be the wiring for me? And also do i need to calibrate my soundboard, spl, etc... ? | ||||
| | #2 | ||||
| Re: New member and RT60 with REW | ||||
| | #3 | |||||
| Re: New member and RT60 with REW Quote: the online help has really a lot of arguments and i feel a bit .... ![]() (sorry for my english) i'll try this way http://www.hometheatershack.com/foru...on-ecm-mic.jpg | |||||
| | #4 | ||||
| Re: New member and RT60 with REW Hopefully, you have read REW Cabling Basics and the REW HELP files. We can certainly help with any specific questions you may have. RT60 results are generally considered not too meaningful in domestic sized rooms and not to be used at all below about 200Hz, and even then are only meaningful when running a main speaker with the sub. For low frequencies use the waterfall and decay plots to see what the room is doing. brucek | ||||
| | #6 | |||||
Here's just one small sampling of strong opinions that you'll find.......... fill your boots ![]() brucek | |||||
| | #7 | ||||
| Re: New member and RT60 with REW I've just tried to install the REW in my MAC to use it with its soundboard but when i start it i get an error: AUDIO INTERFACE ERROR No Input Mixers Available supporting PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little endian However it seems that i solved this problem just choosing the soundboard onboard, but i think there is another problem. If i play with the tone generator playing a sine wave it sound more like a square one, and the pink noise i feel is very dirty... don't know what's the problem but with my pc there wasn't that problem. And if i use another software like SMAARTLIVE on this mac it works well with sweeps, sine leads etc... Do you know what could it be ? | ||||
| | #10 | ||||
| Re: New member and RT60 with REW No, there is just one version of REW. There's a problem with Java accessing the inputs of the soundcard with version 10.4 You require 10.5 for REW brucek | ||||
| | #12 | ||||
| Re: New member and RT60 with REW You also need an Intel Mac for REW to run properly. | ||||
