| REW Forum Surround Measurement - Check My Results?Discuss Surround Measurement - Check My Results? in the Equalization | Calibration forum; Surround Measurement - Check My Results? Greets all.
I'm getting ready to build and deploy some room treatment. I have two portable (155lbs so portable is ... |
Views: 531 - Replies: 12
| Surround Measurement - Check My Results? Greets all. I'm getting ready to build and deploy some room treatment. I have two portable (155lbs so portable is relitive) bass traps ready to be dropped into the corners. I have 18 Panels of JM814 2" semi-ridged I'm going to cut up for a Super-Chunk, and I have 10 panels of 1.5" Thermafiber left over from the portable bass traps. I'm also working on building some poly diffusors for the back wall, and very likely some more JM814 panels for first reflection points. Before I move forward, I want to make sure this looks right. ![]() Yamaha Dolby Digital Surround setup with my favorite DSP setting, Elemental Designs Under-Screen 6T6 Mains with 5T5 rears, Wicked One Sub (36"X36"X14") with a pair of JL Audio 10W7 Dual Voice coil drivers powered by an EP2500. Measurement taken through an ECM8000 through Mackie mixer (set flat) through my HTPC. Mic Cal loaded, Soundcard Cal done. And the chart is 15-20k with 105db top which I'm reading is our standard format around here. I hope I did all that correctly. I'm still winging this, and I just want to make sure my base measurement looks right before I start rolling in sound treatment. Otherwise I won't really have a solid handle on how much change I'm doing. I'm also not sure how to do the RT60 or any of that...which I'm understanding is also important. Though with all the carpet and huge blackout curtains I have, is probably not too bad except for the front to back flutter echo I can clearly hear while clapping (or talking for that matter). Please, chime in any suggestions. I'm going to go cut up some insulation and make me a supa-dupa-chunk! | ||||
| | #2 | |||||
| Re: Surround Measurement - Check My Results? Welcome to the Forum, Raven! Quote:
Since you’ll be adding bass traps, you’ll want to look at “before and after” waterfalls. Did you use our ecmnew calibration file for the mic? Regards, Wayne | |||||
| | #3 | |||||
| Re: Surround Measurement - Check My Results? I've not generated waterfalls for this measurement. Though I looked at some from when I was putzing around with REW trying to figure my way through it. I can generate and post a waterfall if I can get some help in reading it? So I should be doing this only in two channel? I figured since the center channel imparts such a sonic footprint, that it would be included in the measurements. Or am I not understanding a key point? I'll rerun this really quickly with FX off and only run Mains + Sub and post my results. Thanks for the start! ~Eric~ Quote:
| | #4 | ||||
| Re: Surround Measurement - Check My Results? Side note: I have about 8' of 34" face triangles cut out. I'm considering making a wood cage to hold them in 4' sections so I can easily move and measure and compare to my hard-shell portable diffusers. I'm going to eat dinner while I ponder this and see what I come up with. | ||||
| | #5 | ||||||
| Re: Surround Measurement - Check My Results? Quote:
![]() Quote:
Regards, Wayne | ||||||
| | #6 | ||||
| Re: Surround Measurement - Check My Results? OK, here's Sub and Mains, no Surround, no Room Treatment. I had to dial the sub down to almost nothing at it was pinging 105db at the same setting I get 75db in surround mode. And I still have a low freq hump. I wish that hump was at 15Hz! ![]() | ||||
| | #7 | |||||
Similarly my thoughts were that since I'm listening in Surround mode 98% of the time, that I should be doing my measurements in Surround mode and trying to dial in the room in Surround mode. But I will defer to your experience till I get a better grasp of all this. | |||||
| | #8 | |||||
| Re: Surround Measurement - Check My Results? Okay - getting back to your original post: Quote:
Be sure and save your readings, for later comparison.Regards, Wayne | |||||
| | #10 | |||||
Um, yeah, I forgot to save once and shut off the computer...so I'm being extra careful this time to make sure I"m on the right track. | |||||
| | #11 | ||||
| Re: Surround Measurement - Check My Results? For your waterfalls set the axes to 45..105dB and 15..200Hz (use the button second from the right in the toolbar) and change the frequency axis from linear to logarithmic by clicking the button third from right in the toolbar. | ||||
| | #12 | ||||
| Re: Surround Measurement - Check My Results? Thanks, John. I'll take care of that tonight when I get home from work, and post the correct waterfall. | ||||
| | #13 | |||||
brucek | |||||
| Bookmarks |
| Tags |
| check, measurement, results?, surround |
| Thread Tools | |
