REW Forum
Export measurement as text: request
Discuss Export measurement as text: request in the Equalization | Calibration forum; Export measurement as text: request It would be nice if "export measurement as text" put a TAB between the frequency and dB values instead of ...
Views: 308 - Replies: 2
Old 10-04-08, 01:37 AM   #1
Alias: Rick
Loc: Cambria, CA, USA
User: #26415
Since: Sep 2008
  Rick Auricchio is offline
It would be nice if "export measurement as text" put a TAB between the frequency and dB values instead of a space. Doing so would greatly simplify importing into a spreadsheet, like Excel.
Perhaps a choice: space, tab, or comma?
This may also be applicable to other exports as well.
Thanks in advance...I'm really enjoying REW.
Old 10-06-08, 08:28 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Export measurement as text: request
Excel accepts space as a delimiter, just need to select that on the 2nd pane of the Excel text import wizard (after choosing delimited text on the first pane). Tab could be made an option, I'll put that on the features list. Comma is more problematic for locales that use comma as a decimal delimiter.
Old 10-06-08, 12:16 PM   #3
Alias: Rick
User: #26415
Since: Sep 2008
You would think I would know that. I totally missed that Excel takes space as a delimiter, which is absolutely fine.
And you're ahead of me on the comma used as the decimal indicator. I must be sleeping/slipping!
export, measurement, request, text:
