| REW Forum Not sure if this is disturbing, or encouraging...Discuss Not sure if this is disturbing, or encouraging... in the Equalization | Calibration forum; Not sure if this is disturbing, or encouraging... So I finally got around to taking some scans at my cousin's place... I was time limited, so I didn't ... |
Views: 374 - Replies: 9
| Not sure if this is disturbing, or encouraging... So I finally got around to taking some scans at my cousin's place... I was time limited, so I didn't play around with trying to fix what I saw, figured I'd go back there at some point... I'm not sure if these scans disturb me greatly, or if this is easily fixed with the eq's built into his Marantz 5002... please help walk me through the logic... First, he's in an apartment, and didn't much want to hear about proper placement, he already knew where everything was going to go, so that's less than ideal, although for the purposes of these measurements, it's not all that terrible either. Room treatment (much to my chagrin) is simply not an option with him. It's a do-the-best-you-can-with-all-limbs-tied etc. I'm showing two scans, one showing the crossover point between the sub and fronts, and the other full range. In each case, these are averages of the actual scans taken... for each average, I averaged 2 scans each in 4 positions, so each scan here is an average of 8 scans, which nicely smooths out the comb filtering in full range which is why I didn't bother smoothing the curves. I can 2 distinct peaks in the sub response that could be addressed, but what I'm focusing on here is the shelf around 160-200 Hz... The BW of the sub was left wide open, with the AVR's Xover set to 100Hz, so I would not have expected an interaction at 160-240, but is that what I'm looking at? I had EQs on the AVR turned off, in a no-processing mode other than bass management... should this be fixable by just giving gain to the right eq bands in the AVR? Or is something more sinister going on here? (the LCD FP sort of hangs in the middle of the room, could be partially blocking one of the 2 fronts...) I carefully checked the phasing of the fronts, and the sub, with test tones from the THX demo disc... since he is a distance away, I'd like to have a good gameplan before I go back ot fix this to make the most of my time... anyway, here ar ethe scans.. ![]() | ||||
| | #2 | ||||
| re: Not sure if this is disturbing, or encouraging... Forgot to mention I also carefully set levels using RS meter, dont' remember if we used tones from THX demo disc or the internal ones on the AVR... Should be noted that after these scans were taken, we watched some demo material and decided the rears were overpowering the fronts... and increased the gain on the fronts to compensate... so I wonder if they were mis-set to begin with... but then the question would be why? I guess this raises another question, which is, what tones to use? Are the ones in THX ok? Better to use internal tones on the AVR (depending on the AVR?) I assume pink noise is the route to go, but full or BW limited? What limits? | ||||
| | #3 | ||||||
| re: Not sure if this is disturbing, or encouraging... Quote:
But using the full-range graph just as a "for example," the peak centered at about 5 kHz is about the only thing that would need adjusting with the main speakers. The receiver's EQ could probably take care of it, with a few dB cut at 5 kHz. Quote:
The built-in tones in a receiver are sufficient for setting main-channel levels. Regards, Wayne | ||||||
| | #4 | ||||||||
| re: Not sure if this is disturbing, or encouraging... Hi Wayne... Thanks for the response... Quote:
I think that's far enough away from the xover point on the rcvr (100Hz) to worry me that it's not simply a level issue between fronts and sub... also, the steepness particularly disturbed me, as it seemed steep compared to what I imagine a built-into-the-avr-eq to provide? Quote:
![]() Full range scans were taken with sub and front LR... in this case, shouldn't be an issue... as this dropoff was seen in all 8 scans taken in four different listening positions, I don't think it's a simple interaction between the 2 front speakers such as a phase mistake... Quote:
![]() Seriously, though, better to use the receiver's built in stuff, as opposed to a tone form a dvd or even REW's own generator? | ||||||||
| | #5 | ||||||||
| Re: Not sure if this is disturbing, or encouraging... Quote:
![]() Regards, Wayne | ||||||||
| | #6 | ||||||||
| | #7 | ||||||||
| | #8 | ||||
| Re: Not sure if this is disturbing, or encouraging... I thought I replied to this already, but no matter, because I think some things just got through my thick head after staring at REW for a while... Mainly, that a phasing issue doesn't necessarily imply a wiring mistake, but can simply be due to the relative positions of the sub/mains... yes? Then, the phase interaction at any given frequency will be different, as it depends on pathlength as % of wavelength, yes? In other words the same phase issue presents itself as constructive interference at some points, destructive at others, and vanishes at others? Therefore, it's possible that a falloff just below the xover, flattening at the xover and peaking just after the xover could all be phasing, and then the drop to the mains level is as the mains level out and the sub finishes its rolloff? Of course, that could explain the iregularities, but the question would still remain what happened? I used the RS and cycling through the speakers set everything to 75db (+/-1), but running the sweep proves a vastly different level? | ||||
| | #9 | ||||
| Re: Not sure if this is disturbing, or encouraging... Follow up... it's inconvenient to putt the avr out to get access to the multi inputs, is there (generally) another easy way to run the sub without the mains that I might be overlooking? I figure the mains could be rnu without the sub my simply turning the sub off temporarily... | ||||
| | #10 | |||||
| Bookmarks |
| Tags |
| encouraging..., isdisturbing |
| Thread Tools | |
