REW Forum
What do I do AFTER I upload REW filters to the BFD?
Discuss What do I do AFTER I upload REW filters to the BFD? in the Equalization | Calibration forum; What do I do AFTER I upload REW filters to the BFD? I've been trying to read as many guides and FAQs as I can, and this isn't clear to me. What ...
Views: 316 - Replies: 5
Old 10-06-08, 03:55 PM   #1
Alias: RobertR
Loc: Riverside, CA
User: #5951
Since: Jan 2007
  RobertR is offline
I've been trying to read as many guides and FAQs as I can, and this isn't clear to me. What exactly do I do after I upload the REW filters? What should I see on the BFD display and the buttons/switches? Should segments on the 12 filter per channel LED display be lit up? What should be the state of the in/out switch?
Old 10-06-08, 09:09 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: What do I do AFTER I upload REW filters to the BFD?
Well, I've never done the auto-load, but I expect you'll see the red filter lights come on. Otherwise, no filters are loaded. Don't see where the in/out switch has any relavance as part of the auto-load: If the EQ is switched out, just engage it.
Old 10-06-08, 09:42 PM   #3
Alias: RobertR
Loc: Riverside, CA
User: #5951
Since: Jan 2007
  RobertR is offline
Hi Wayne,
My problem is that I don't see the red filter lights come on, even though I've autoloaded filters. I think I'm doing something wrong, but I don't know what.
Old 10-06-08, 10:42 PM   #4
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
It sounds like you either did not get the filters loaded or as Wayne suggest, the eq is not engaged.
There should be a red LED for every filter you uploaded to the BFD and the green LED should be lit steady on the IN/OUT button.
Old 10-08-08, 11:43 AM   #5
Alias: RobertR
Loc: Riverside, CA
User: #5951
Since: Jan 2007
  RobertR is offline
I'll play around with it more this weekend.
Old 10-08-08, 06:06 PM   #6
Alias: Wayne
Loc: Katy, Texas
User: #8
If the filters aren't loading, it's may be because your BFD can't do it. There was a production period when the firmware for filter loading didn't work right. However, it's easy enough to load them manually, since REW's filter panel displays the exact values the BFD uses.
bfd?, filters, upload
