| REW Forum What volume controls to use once filters installed?Discuss What volume controls to use once filters installed? in the Equalization | Calibration forum; What volume controls to use once filters installed? I have read Sonnie's BFD installation guidelines but need to better understand how to control volume once bfd filters are ... |
Views: 328 - Replies: 6
| What volume controls to use once filters installed? I have read Sonnie's BFD installation guidelines but need to better understand how to control volume once bfd filters are loaded without changing input levels. Can I increase volume using avr or only use volume control on the sub and if I want to increase volume of main speakers then I would use avr volume control. I just need to better understand the rules. cheers Dwight | ||||
| | #3 | |||||
| Re: What volume controls to use once filters installed? Quote:
The situation hasn't changed much after inserting a BFD, other than you should not disturb the setting you set on the AVR sub trim because you may cause clipping or low level inputs into the BFD. So, use the subwoofers own amplifier volume to balance levels rather than the AVR sub trim. brucek | |||||
| | #4 | ||||
| Re: What volume controls to use once filters installed? Thanks Brucek Regarding the pre bfd installation I followed what you outlined. I then installed the bfd and increased avr subtrim to +3 so bfd vu meter would occasionally blink yellow at max listening volume level. I needed to turn up avr volume after installing BFD filters as volume was too low. I did not change the sub trim and it remains at +3. I just increased avr volume. Is this correct ? | ||||
| | #5 | ||||
| Re: What volume controls to use once filters installed? Steven Yeah that's my problem once I set the filters I want to increase volume as it is too low. If I increase avr volume then this will distort my input levels used for bfd filters. I am just looking for the right process to keep input levels intact. cheers Dwight | ||||
| | #6 | |||||
brucek | |||||
| Bookmarks |
| Tags |
| controls, filters, installed?, volume |
| Thread Tools | |
