REW Forum
What sound card should I get for a Mac
Discuss What sound card should I get for a Mac in the Equalization | Calibration forum; What sound card should I get for a Mac I'm new to REW and I'm looking for the least expensive sound card that will be accurate and easy to ...
Views: 380 - Replies: 1
Old 10-08-08, 09:07 PM   #1
Alias: nick
User: #14227
Since: Dec 2007
  nickwin is offline
I'm new to REW and I'm looking for the least expensive sound card that will be accurate and easy to use with my macbook pro (I'm willing to spend a little extra if it will simply things) any advise would be appreciated.
Old 10-09-08, 01:03 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: What sound card should I get for a Mac
Macbook Pros work with the internal soundcard as they accept line-in (most laptops do not).
See this thread where a member tells how it is set up...
card, sound
