REW Forum
How does this graph look after BFD?
Discuss How does this graph look after BFD? in the Equalization | Calibration forum; How does this graph look after BFD? Hi, I'm new to the world of equalizing and BFD. I've MFW-15 subwoofer xover at 80 hz. I did the ...
Views: 399 - Replies: 2
Old 10-11-08, 01:06 PM   #1
New Member
Alias: pHd
Loc: Illinois
User: #20101
Since: Apr 2008
  plasmahidef is offline
Question How does this graph look after BFD?
Hi,
I'm new to the world of equalizing and BFD. I've MFW-15 subwoofer xover at 80 hz. I did the measurements manually using Excel and RS meter + CD test tones. The graph shows the measurements before and after equalizing with BFD. Is the dip at around 100 hz a normal thing? Thanks for looking at it and sharing your thoughts on it.
Regards.
Old 10-11-08, 01:24 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: How does this graph look after BFD?
Looks quite good.
Any peaks or dips after the crossover can be ignored until you add the mains and do a new measure. Then the phase control of the sub is used to get the best transition around the crossover.
I'm moving this to the REW section
Old 10-14-08, 07:08 AM   #3
New Member
Alias: pHd
Loc: Illinois
User: #20101
Since: Apr 2008
Thanks Brucek. I'll do the measurement again with the mains, when I get the chance and will see how it looks.
Regards.
bfd?, graph
