REW Forum
measuring noise criteria with REW
Discuss measuring noise criteria with REW in the Equalization | Calibration forum; measuring noise criteria with REW Is there a way to measure the noise criteria(NC15,NC20,NC25 etc.) of a room with the waterfall plots by looking at ...
Views: 522 - Replies: 2
Old 10-11-08, 03:44 PM   #1
Alias: D
Drudge's Avatar
Loc: Florida
User: #25138
Since: Sep 2008
  Drudge is offline
Is there a way to measure the noise criteria(NC15,NC20,NC25 etc.) of a room with the waterfall plots by looking at the 1/3 octave bands (63,125,250,500,1000,2000,4000,8000HZ) or do I have to take a seperate SPL reading for each band and then look at the published charts to see where my noise floor matches up to the different ratings?
Old 10-12-08, 08:06 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: measuring noise criteria with REW
REW doesn't calculate noise criteria, but read this post to show how to measure noise with REW.
Old 10-12-08, 03:20 PM   #3
Alias: D
Drudge's Avatar
Loc: Florida
User: #25138
Since: Sep 2008
  Drudge is offline
Well,what I was thinking of doing was when I lower the dB scale of the waterfall chart to around 35dB
or lower there seems to be a plateau of ringing that I was assuming was the noise floor but,I'm probably
wrong.There is a chart that shows what level in dB that each of the octave ranges should measure but not
exceed in level for each NC rating.I was going to look at the waterfall at each of those ranges and see were they match up to which NC rating.
But I didn't know if that would be a correct way,Thanks brucek
criteria, measuring, noise
