| REW Forum Some measurements I took..Discuss Some measurements I took.. in the Equalization | Calibration forum; Some measurements I took.. I finally got around and had the time to take a few measurements... my setup is a 4 driver IB(tempests) ... |
Views: 359 - Replies: 2
| Some measurements I took.. I finally got around and had the time to take a few measurements... my setup is a 4 driver IB(tempests) sub powered by a Crest 2600 at 2 ohms... or 1100 watts per pair. First measurement no eq. I took a few more... to be sure and one with a +5 boost at around 20 hz.. This is the info on Rew... SPL measurement data saved by Room EQ Wizard V4.11 Source: Input device not selected, no input selected, Right channel, volume: no control Format: 512k Log Swept Sine, 1 sweep using mic/meter cal file: C:\Documents and Settings\Administrator\Desktop\RADIOSHACK-33-2055_4050.cal using soundcard cal file: C:\Documents and Settings\Administrator\Desktop\RADIOSHACK-33-2055_4050.cal Dated: 12-Oct-2008 6:55:35 PM REW Settings: C-weighting compensation: On Target level: 75.0 dB Note: last meas Measurement: Oct 12 18:55:35 Frequency Step: 0.36561334 Hz Start Frequency: 9.979248 Hz 9.979 68.871 10.345 69.646 10.710 70.856 11.076 71.964 11.442 72.846 11.807 73.454 12.173 73.847 12.539 74.171 12.904 74.447 13.270 74.837 13.635 75.381 14.001 75.968 14.367 76.517 14.732 76.956 15.098 77.251 15.463 77.423 15.829 77.499 16.195 77.575 16.560 77.755 16.926 77.937 17.292 78.138 17.657 78.348 18.023 78.551 18.388 78.709 18.754 78.870 19.120 79.045 19.485 79.301 19.851 79.505 20.216 79.701 20.582 79.952 20.948 80.222 21.313 80.517 21.679 80.818 22.044 81.067 22.410 81.218 22.776 81.198 23.141 81.017 23.507 80.774 23.873 80.578 24.238 80.601 24.604 80.889 24.969 81.310 25.335 81.653 25.701 81.886 26.066 82.043 26.432 82.233 26.797 82.452 27.163 82.716 27.529 83.002 27.894 83.247 28.260 83.410 28.626 83.526 28.991 83.695 29.357 84.037 29.722 84.512 30.088 85.022 30.454 85.398 30.819 85.600 31.185 85.581 31.550 85.323 31.916 84.780 32.282 83.963 32.647 82.918 33.013 81.780 33.379 80.840 33.744 80.562 34.110 81.133 34.475 82.306 34.841 83.537 35.207 84.560 35.572 85.266 35.938 85.630 36.303 85.615 36.669 85.234 37.035 84.513 37.400 83.490 37.766 82.234 38.131 80.891 38.497 79.676 38.863 78.784 39.228 78.209 39.594 77.766 39.960 77.278 40.325 76.738 40.691 76.179 41.056 75.745 41.422 75.514 41.788 75.559 42.153 75.745 42.519 75.934 42.884 75.970 43.250 75.833 43.616 75.540 43.981 75.135 44.347 74.656 44.713 74.182 45.078 73.754 45.444 73.375 45.809 73.057 46.175 72.823 46.541 72.719 46.906 72.806 47.272 73.085 47.637 73.500 48.003 73.967 48.369 74.422 48.734 74.825 49.100 75.174 49.465 75.486 49.831 75.822 50.197 76.239 50.562 76.765 50.928 77.368 51.294 77.973 51.659 78.535 52.025 79.020 52.390 79.469 52.756 79.817 53.122 80.081 53.487 80.293 53.853 80.506 54.218 80.736 54.584 80.977 54.950 81.200 55.315 81.380 55.681 81.460 56.047 81.406 56.412 81.179 56.778 80.816 57.143 80.353 57.509 79.848 57.875 79.302 58.240 78.753 58.606 78.231 58.971 77.762 59.337 77.363 59.703 77.044 60.068 76.803 60.434 76.627 60.800 76.489 61.165 76.356 61.531 76.197 61.896 75.989 62.262 75.716 62.628 75.377 62.993 74.980 63.359 74.542 63.724 74.085 64.090 73.631 64.456 73.202 64.821 72.800 65.187 72.434 65.552 72.119 65.918 71.874 66.284 71.673 66.649 71.545 67.015 71.502 67.381 71.588 67.746 71.718 68.112 71.871 68.477 72.028 68.843 72.169 69.209 72.286 69.574 72.392 69.940 72.515 70.305 72.653 70.671 72.825 71.037 73.023 71.402 73.243 71.768 73.437 72.134 73.596 72.499 73.731 72.865 73.873 73.230 74.012 73.596 74.148 73.962 74.279 74.327 74.430 74.693 74.560 75.058 74.661 75.424 74.726 75.790 74.779 76.155 74.825 76.521 74.856 76.886 74.849 77.252 74.782 77.618 74.653 77.983 74.465 78.349 74.226 78.715 73.935 79.080 73.599 79.446 73.238 79.811 72.865 80.177 72.505 80.543 72.176 80.908 71.885 81.274 71.629 81.639 71.399 82.005 71.180 82.371 70.960 82.736 70.729 83.102 70.482 83.468 70.224 83.833 69.963 84.199 69.711 84.564 69.479 84.930 69.272 85.296 69.086 85.661 68.913 86.027 68.750 86.392 68.596 86.758 68.456 87.124 68.335 87.489 68.236 87.855 68.163 88.221 68.121 88.586 68.120 88.952 68.167 89.317 68.263 89.683 68.400 90.049 68.564 90.414 68.740 90.780 68.918 91.145 69.095 91.511 69.269 91.877 69.438 92.242 69.603 92.608 69.762 92.973 69.916 93.339 70.067 93.705 70.214 94.070 70.359 94.436 70.501 94.802 70.643 95.167 70.788 95.533 70.942 95.898 71.106 96.264 71.278 96.630 71.454 96.995 71.627 97.361 71.794 97.726 71.958 98.092 72.123 98.458 72.292 98.823 72.466 99.189 72.640 99.555 72.806 99.920 72.960 100.286 73.098 100.651 73.220 101.017 73.329 101.383 73.426 101.748 73.510 102.114 73.580 102.479 73.633 102.845 73.666 103.211 73.680 103.576 73.672 103.942 73.637 104.307 73.573 104.673 73.476 105.039 73.347 105.404 73.192 105.770 73.021 106.136 72.842 106.501 72.664 106.867 72.488 107.232 72.317 107.598 72.151 107.964 71.998 108.329 71.867 108.695 71.767 109.060 71.700 109.426 71.663 109.792 71.643 110.157 71.629 110.523 71.609 110.889 71.578 111.254 71.534 111.620 71.475 111.985 71.405 112.351 71.327 112.717 71.246 113.082 71.165 113.448 71.087 113.813 71.014 114.179 70.947 114.545 70.883 114.910 70.821 115.276 70.758 115.642 70.691 116.007 70.621 116.373 70.551 116.738 70.488 117.104 70.438 117.470 70.404 117.835 70.379 118.201 70.350 118.566 70.305 118.932 70.239 119.298 70.157 119.663 70.068 120.029 69.985 120.394 69.914 120.760 69.853 121.126 69.793 121.491 69.730 121.857 69.660 122.223 69.587 122.588 69.514 122.954 69.442 123.319 69.363 123.685 69.270 124.051 69.154 124.416 69.011 124.782 68.844 125.147 68.660 125.513 68.465 125.879 68.268 126.244 68.073 126.610 67.882 126.976 67.696 127.341 67.513 127.707 67.332 128.072 67.150 128.438 66.967 128.804 66.782 129.169 66.597 129.535 66.413 129.900 66.232 130.266 66.054 130.632 65.876 130.997 65.691 131.363 65.495 131.728 65.287 132.094 65.073 132.460 64.863 132.825 64.664 133.191 64.480 133.557 64.304 133.922 64.130 134.288 63.948 134.653 63.759 135.019 63.567 135.385 63.381 135.750 63.202 136.116 63.030 136.481 62.860 136.847 62.690 137.213 62.522 137.578 62.361 137.944 62.207 138.310 62.059 138.675 61.909 139.041 61.750 139.406 61.580 139.772 61.403 140.138 61.227 140.503 61.057 140.869 60.894 141.234 60.733 141.600 60.564 141.966 60.383 142.331 60.192 142.697 60.000 143.062 59.817 143.428 59.646 143.794 59.479 144.159 59.299 144.525 59.094 144.891 58.863 145.256 58.620 145.622 58.383 145.987 58.162 146.353 57.950 146.719 57.732 147.084 57.497 147.450 57.253 147.815 57.022 148.181 56.826 148.547 56.665 148.912 56.514 149.278 56.342 149.644 56.132 150.009 55.896 You guys see any area I can improve on? Thanks... | ||||
| | #2 | ||||
| Re: Some measurements I took.. Your sweep measurement should be set to 0Hz-200Hz and then the graphs posted with a vertical scale of 45dB-105dB and a horizontal scale of 15Hz-200Hz. No data is required. Post graphs 800 pixels wide. I would say it looks quite good, but you need some EQ around 35Hz and around 55Hz. I would remove the boost at 20Hz. brucek | ||||
| | #3 | ||||
| Re: Some measurements I took.. I'd remove the 20 Hz boost filter and use a couple of filters to lower response below ~40 Hz to the 75 dB Target Curve. Then maybe cut the peak at ~55 Hz. Regards, Wayne | ||||
| Bookmarks |
| Tags |
| measurements, took.. |
| Thread Tools | |
