REW ForumDiscuss Soundcard Calibration? in the Equalization | Calibration forum; Soundcard Calibration? I'm doing intial setups. My intial soundcard readings to create my calibration file and my post calibration check readings with ... |
Views: 781 - Replies: 2
| | #2 | ||||
| Re: Soundcard Calibration? Most likely not selecting a different tab to make the check measurement. Measurements made while on the soundcard tab do not use the cal data (else you wouldn't get a no-cal measurement to make the data in the first place). | ||||
| | #3 | ||||
| Re: Soundcard Calibration? John, Thanks for the reply. This indeed makes perfect sense. I think I stumbled upon this last night when going ahead and doing an intial measurement, I just didn't know how I got their!! I'll try it out! Thanks again, Ross | ||||
