REW Forum
how to read an impulse response?
Discuss how to read an impulse response? in the Equalization | Calibration forum; how to read an impulse response? Hello this is my 1st impulse readout at the mix position at 3 feet from speakers - i,m trying to ...
Views: 476 - Replies: 13
Old 10-24-08, 07:48 AM   #1
Alias: asylum
User: #13915
Since: Nov 2007
  asylum is offline
Hello this is my 1st impulse readout at the mix position at 3 feet from speakers - i,m trying to interpret the reading?
is the high spike at 0 the sound hitting the mic? what do the other peaks and troughs mean, or is it the spike at about 3ms the 1st sound hitting the mic? all help appreciated
regards
jim
Old 10-24-08, 11:05 AM   #2
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Re: how to read an impulse response?
I don't know your room geometry, but it looks like 0 is the first incident and the second spike corresponds to a reflection roughly 3.3 ft longer path length. Since you said the mic was 3 ft from the source, I would be looking for any path that is around 6' for the reflection.
Probably floor, although it could also be back wall.
For single speaker measurements it's always best to move everything as far from boundaries as possible in order to measure as long a time without that second reflection. Once you get into that the comb filtering from out of phase room effects starts to intrude. Still an issue, but not a fundamental flaw with the speaker itself.
The trade off is that if you set your gate too narrow, you lose bass information, which is why large open spaces are best for speaker testing. None of those pesky reflections to deal with
Old 10-24-08, 01:14 PM   #3
Alias: brucek
User: #6
  brucek is online now
For impulse you want to use dBFS as the Y-Axis and not %FS.
If you're looking for determining reflections, it's better to use Energy Time plots in %FS.
Old 10-25-08, 11:47 AM   #4
Alias: asylum
User: #13915
Since: Nov 2007
  asylum is offline
Thanks for the reply and great info - so would be right in presumong the 1st peak at 0
is the ipulse hitting the microphone, but i am confused should the 1st wavefront hit the mic at 3 ms later due to the speed of sound, also what does the negative side of the waveform mean? thanks again -
Old 10-25-08, 11:51 AM   #5
Alias: asylum
User: #13915
Since: Nov 2007
  asylum is offline
Hi Bruce thanks for helping a newbie to this software, it really is great, could you point in the direction of any online info on how to read the impluse response, or is there any around here, like what should i be looking for, and in what window what is the difference of dB% vs dBfs?
does that mak sense, thanks?
Old 10-25-08, 02:11 PM   #6
Alias: brucek
User: #6
so would be right in presuming the 1st peak at 0 is the impulse hitting the microphone
Yes, there is no real time reference (unless you use the left channel as reference feature), so the main signal is the large first peak you see. As time progresses you will see any further reflections as small peaks in the signal that you can measure with the cursor from the main peak until the signal drops into the noise floor.
The signal before the main peak reveals system distortion. You may see smaller copies of the main peak there which represent a distortion harmonic. The first peak before zero is the 2nd harmonic and the next peak is the third harmonic, etc.
After the main peak are the reflections that took longer to get to the microphone than the initial main peak. The timing can show how much further thay had to travel to reach the microphone. So, if your mic was 10 feet from the speaker (main peak at zero), and the distance to hit a wall and get to the mic was 15 feet, then you would see a spike at 5msec (given the speed of sound).
Again, these reflections are a bit easier to see with the Energy Time tab plots. Full range speakers as opposed to the lower bandwidth subwoofer responses are far easier to detect, because they'll show as a nice spike rather than a wide lobe.
Old 10-26-08, 07:24 AM   #7
Alias: asylum
User: #13915
Since: Nov 2007
  asylum is offline
Yes i am using the left channel feature, the confusing part for me is if the timeline is in ms and with the speed of sound hitting the mic and if the mic is3 feet from the source, should the 1st peak be at 3 ms and not at the 0 position, and after that reflections?
Old 10-26-08, 08:01 AM   #8
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
The zero position on the impulse plot is set to the first point the response goes 10% above the peak value, to remove the source to microphone delay.
Old 10-26-08, 08:06 AM   #9
Alias: asylum
User: #13915
Since: Nov 2007
  asylum is offline
the the 1st peak is really at 3 ms but its all shifted forward to line up at 0 on the time line so the delay is taken out?
Old 10-26-08, 10:17 AM   #10
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
That's correct. So the second peak 3ms later corresponds to the first reflection, which is about 5' longer in path than straight speaker-to-mic.
Old 10-26-08, 10:44 AM   #11
Alias: asylum
User: #13915
Since: Nov 2007
  asylum is offline
why 5' foot longer?
Old 10-26-08, 10:51 AM   #12
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
1125 ft/second X 0.003 ms which is about 3.4 ft, not 5. Sorry, I did the calculation in my head before my coffee kicked in.
That's the speed of sound times the time it took to travel.
Old 10-26-08, 10:59 AM   #13
Alias: asylum
User: #13915
Since: Nov 2007
  asylum is offline
so if i get this right the 1st reflection is at 3.4' approx, so i can look at that and measure with a tape measure all surfaces around that distance and expect to see something eg a boundary wall/floor/ceiling? so with regard the rest of the tail how should i interpret file? is there any info on this subject on the net?
thanks again for taking the time to discuss this anthony
Old 10-26-08, 11:05 AM   #14
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
It would be 3.4' longer than your speaker to mic distance. So if that was 3', you would be looking for a 6.4'. Most likely it would be from speaker to back wall to mic, or speaker to floor to mic.
Glad to help.
impulse, read, response?
