REW Forum
Calibrating like subs using REW and BDF
Discuss Calibrating like subs using REW and BDF in the Equalization | Calibration forum; Calibrating like subs using REW and BDF Since the BDF has dual channels can you use both channels to calibrate each sub, or would it be better ...
Views: 292 - Replies: 4
Old 10-25-08, 03:48 PM   #1
Alias: Carl Slaughter
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Since the BDF has dual channels can you use both channels to calibrate each sub, or would it be better to calibrate both subs at the same time using a single channel? So use the left channel of the BFD and calibrate that sub, then use the right channel to calibrate the right sub, or use both channels at the same time to calibrate both subs together. I have 2 Sub outs on my receiver.
Old 10-25-08, 03:56 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Calibrating like subs using REW and BDF
Either way is fine.
Old 10-25-08, 04:02 PM   #3
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Same make model sub and currently they are located under the screen next to the mains. Not a lot of options as they are BIG!
Old 10-25-08, 05:00 PM   #4
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Are there any calibrations files needed with the Beheringer setup?
Old 10-25-08, 08:10 PM   #5
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
There's a whole subforum here with downloads for REW. In there you'll see our "standard" ECM8000 mic. We did a lot of comparisons with different mics, and for sub work that one will suit you well.
As for preamp/soundcard calibrations, you need to do those as part of the REW setup. The instructions for those are in the help file.
Good luck.
calibrating, subs
