| REW Forum Taking mic readings...Discuss Taking mic readings... in the Equalization | Calibration forum; Taking mic readings... When taking readings with REW..where is the best place to install the mic.. ? I usually set it on a ... |
Views: 276 - Replies: 5
| Taking mic readings... When taking readings with REW..where is the best place to install the mic.. ? I usually set it on a tripod in front of my IB subs...right about the middle about 10 inches from them. What do you guys do? | ||||
| | #4 | |||||
| Re: Taking mic readings... Quote:
To know what your IB (or your mains, or the combination) is doing as you hear it, the mic should be approximately where your head is when you are listening. You can get excited and put the microphone in each listening position if you have multiple seats and work toward optimizing them collectively, but generally putting it in the "prime" listening position is enough for most folks. The "cheap seats" will just have less-than-optimal response in that case. | |||||
| | #5 | |||||
As tenzip explains, the only place you're interested in the response is where you sit.. bruce | |||||
| | #6 | |||||
I think I got mixed up between the FR and what your ears hear at sitting/listening position. Thanks guys! Time to re do my tests.. ![]() | |||||
| Bookmarks |
| Tags |
| readings..., taking |
| Thread Tools | |
