| REW Forum REW working with the DEQ 2496 Equalizer?Discuss REW working with the DEQ 2496 Equalizer? in the Equalization | Calibration forum; REW working with the DEQ 2496 Equalizer? Greetings!
Anybody using the model DEQ2496 Equalizer? (made by behringer)
Since its related to the BFD, Is there a chance ... |
Views: 681 - Replies: 6
| REW working with the DEQ 2496 Equalizer? Greetings! Anybody using the model DEQ2496 Equalizer? (made by behringer) Since its related to the BFD, Is there a chance that this Equalizer will work with REW as far as setting up say shelving filters or parametric adjustments? Was idealy hoping for a seamless type of relationship to save time. How long is the REW learning curve supposed to take? On average, How many weekends does it take to get things improved? I have some technical inclination, but I don't make my living on technology. Thankyou for any insight Good Health and best regards, Greg | ||||
| | #2 | ||||||
| Re: REW working with the DEQ 2496 Equalizer? Quote:
Hopefully, you will first read and become completely familiar with REW Cabling Basics and the REW HELP files. brucek | ||||||
| | #3 | ||||||
![]() Like brucek said, check the help files first. ![]() Quote:
![]() Regards, Wayne | ||||||
| | #4 | ||||
| Re: REW working with the DEQ 2496 Equalizer? The FBQ2496 doesn't have any problems with filter settings transfer, but the DEQ2496 uses a different prototocol. | ||||
| | #5 | ||||
| Re: REW working with the DEQ 2496 Equalizer? One thing you might not be aware of with the DEQ is that it doesn't have quite as much flexibility with it's parametric filters as the other units they seem to have only included the most common filter settings so there are gaps in the parametric ranges. I just try to pick the closest matching filter manually if there isn't the exact one available(provided it matches fairly closely otherwise I leave it alone)through the DEQ. | ||||
| | #6 | ||||
| Re: REW working with the DEQ 2496 Equalizer? Many good points duly noted. I lookforward to corresponding further after initial setup is performed. Gentlemen, Very kind of you to help. May I ask a question ? It appears the DEQ 2496 may not be as widely deployed as other hardware. Is it still appropriate to discuss it in this particular forum---Or is this sort of thing better left to another forum or private messaging? Follow up question: Is thanking people in this public forum considered a type of spam that would be better left to private messaging? Please clarify, Best, Greg | ||||
| | #7 | ||||
| Re: REW working with the DEQ 2496 Equalizer? Equalizer-specific questions - connection issues, how-to-use it, etc. - should go to the BFD Forum. All REW issues and questions, including graphs, go here. ![]() Sure, kudos are no problem! Regards, Wayne | ||||
| Bookmarks |
| Tags |
| 2496, equalizer?, working |
| Thread Tools | |
