REW Forum
BFD or DEQ 2496
Discuss BFD or DEQ 2496 in the Equalization | Calibration forum; BFD or DEQ 2496 I am planning on using REW for use with either BFD or DEQ 2496. I am also (somtime soon) going ...
Views: 475 - Replies: 5
Old 11-03-08, 10:40 PM   #1
Alias: Eccentric
Loc: Gold Coast, Qld,Australia
User: #10564
Since: Jul 2007
  Jason Schultz is offline
BFD or DEQ 2496
I am planning on using REW for use with either BFD or DEQ 2496. I am also (somtime soon) going to build new speakers. So I noticed that the DEQ 2496has an RTA function inbuilt along with phantom power for a mic such as Behringer ECM 8000.
Now the question is, since i have not purchased any of this hardware yet. which combination would be the most handy for a duel purpose of room correction and speaker design. Is the RTA in the DEQ a better tool for speaker design than REW? or am i wasting my money when REW + BFD can do the same thing.
Old 11-04-08, 09:55 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: BFD or DEQ 2496
The BFD is best reserved for sub woofer equalization.
I don't see the advantage of the RTA in the DEQ, since REW already has an RTA.
Old 11-04-08, 08:23 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: BFD or DEQ 2496
Plus, REW's RTA has 1/24-octave resoluution, while the DEQ's is only 1/6-octave. To be honest that's probably sufficient for most applications, but there's no sense paying an extra $200 for it when REW is free.
Since you're going to be building some speakers, we usually recommend using the Behringer ECM8000 mic along with the Xenyz 802 mini-mixer as a cost effective way to move up from subwoofer measurement to full-range. But if you don't have a sound card yet, you might want to consider the option of a combination sound card/mic preamp instead. It'll cost a bit more, but it'll simplify connections.
Here are a few of the more economical ones from ZZ sounds: The requirements for any sound card/mic pre combo under consideration would be USB, phantom power, and analog outputs.
http://www.zzounds.com/item--MDOMOBILEPRE
http://www.zzounds.com/item--ALEIO2
http://www.zzounds.com/item--EMU0404
Of course, eBaying any of the things needed for REW - mic, mixer, sound card or combo unit - is a good option. Most of this gear is used in home studios, and as such is subjected to no abuse.
Old 11-05-08, 04:22 AM   #4
Alias: Eccentric
User: #10564
Since: Jul 2007
Re: BFD or DEQ 2496
Thanks heaps guys.! This is just the sort of feedback i was after. Wayne I'm very interested in that first M audio preamp/sound card combo. If I had one of these then all i need is the ECM 8000 which is relativly inexpensive. I already have an SPL meter equivalent to the galaxie CM 130.
Do you know if that first product is Vista compatable?
Old 11-05-08, 04:56 AM   #5
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: BFD or DEQ 2496
Hi Jason,
I haven't personally used any of them. I just Googled "usb mixer" to find some examples for your post.
Old 11-05-08, 08:45 AM   #6
Alias: brucek
User: #6
Re: BFD or DEQ 2496
It would appear so..... yes
2496
