Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
REW Forum
  Discuss Problem running REW: can't load standard profile in the Equalization | Calibration forum; Problem running REW: can't load standard profile Hello, I'm a newbie from Brazil. I'm trying to run REW but it keeps showing a java exception: "Can't load ...
Views: 718 - Replies: 4
Old 11-04-08, 05:59 AM   #1
felipe
Inactive
Alias:
User: #
Posts: n/a
Hello,
I'm a newbie from Brazil. I'm trying to run REW but it keeps showing a java exception: "Can't load standard profile: GRAY.pf" and after that, the program ends. Is there a work around? Could you help me on that?
Felipe
Old 11-04-08, 08:11 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Problem running REW: can't load standard profile
What operating system? If you are running Windows and using a third-party theme, try using one of the built-in Windows themes.
Old 11-04-08, 09:11 AM   #3
felipe
Inactive
Alias:
User: #
Posts: n/a
Hello JohnM,
I'm running Windows Vista Home Premium, 32bits, and i'm using the windows vista theme.
The problem happens when the initial progress bar at startup shows the message "Generating tool bar". Then the message box indicating a exception during startup appears. See the details bellow. It seems that the program is expecting a GRAY.pf file but it can't find, so it stops the execution.
Exception during startup
java.lang.IllegalArgumentException: Can't load standard profile: GRAY.pf
Level:
SEVERE
Stack Trace:
java.awt.color.ICC_Profile$2.run(Unknown Source)
java.security.AccessController.doPrivileged(Native Method)
java.awt.color.ICC_Profile.getStandardProfile(Unknown Source)
java.awt.color.ICC_Profile.getInstance(Unknown Source)
java.awt.color.ColorSpace.getInstance(Unknown Source)
roomeqwizard.KA.D(Unknown Source)
roomeqwizard.KA.setEnabled(Unknown Source)
roomeqwizard.RA.<init>(Unknown Source)
roomeqwizard.E.C(Unknown Source)
roomeqwizard.E.<init>(Unknown Source)
roomeqwizard.UA.<init>(Unknown Source)
roomeqwizard.RoomEQ_Wizard.main(Unknown Source)
Best regards,
Felipe
Old 11-04-08, 09:43 AM   #4
Alias: brucek
User: #6
  brucek is offline
I just looked in my laptop, which uses the same Vista operating system as you have, and there is the file in question, located in the Java library.
C:\Program Files\Java\jre1.6.0_07\lib\gray.pf
Actually it shows in four Java libraries, still there from Java updates. (jre1.6.0_02, jre1.6.0_04, jre1.6.0_05, jre1.6.0_07)
I think you need to reload Java.....
Old 11-04-08, 11:22 AM   #5
felipe
Inactive
Alias:
User: #
Posts: n/a
Thank you!
I installed the last version of Java SE and now it is running ok!
can't, load, problem, profile, rew:, running, standard
Bookmark and Share
Dish Network
