| REW Forum Does this look right ?Discuss Does this look right ? in the Equalization | Calibration forum; Does this look right ? Do these graphs look like I at least have my hookup correct ?... |
Views: 279 - Replies: 4
| | #2 | |||||
| Re: Does this look right ? You may be experiencing the effect of low Q and high Q resonances. Quote:
| | #4 | ||||
| Re: Does this look right ? The 1st graph is my sub, the 2nd is my right channel mains. This is my 1st attempt at this, I'm not sure what I am looking at or what this means. My setup is Denon 3806 7.1 with JAMO "small" wall mounted with 200 watt JAMO 8" Sub Any gudiance/ advice would be welcome. I'm recovering from shoulder surgery and have alot of time on my hands | ||||
| | #5 | ||||
| Re: Does this look right ? A good practice is to start with the sub alone with the mains shut off (disconnected), so you can see how the sub reacts with your room without any other influence. Be sure to have the crossover set that you normally use. Then, when you have the sub located and EQ'd the best you can, add the mains and adjust the subs phase to get the best crossover transition. brucek | ||||
