REW ForumDiscuss Noob question: all my measurings look flat in the Equalization | Calibration forum; Noob question: all my measurings look flat hi guys, just started today with the program. step1: after reading the manual, I tried to calibrate the soundcard. output ... |
Views: 581 - Replies: 2
| Noob question: all my measurings look flat hi guys, just started today with the program. step1: after reading the manual, I tried to calibrate the soundcard. output ==> directly to input (with jack) I made the test signal check and had output and input signals. I press "measure" and it makes the sweep. I see it on input and output. Result: absoulte perfect line from 0 hz to 20'000 hz. I believe in Mackie but I can not imagine, that this is realistic ![]() step2: I calibrated the output to 75dB (with an external mic DB device). I put on a microphone into the preamp of my mackie-unit. I used the raw-subwoofer. all levels ok, sweep takes place... an absoulte linear graph as a result. I also tried the manual sweeps.. they work great.. so I have definitly output or the program working ![]() I am doing something fundamentaly wrong.. what is the problem? | ||||
| | #2 | ||||
| Re: Noob question: all my measurings look flat You have a 'monitor mode' enabled in your soundcard and the signal is looping back internally and not through the line-in and line-out. Search your settings and disable the monitor mode. brucek | ||||
