REW Forum
peaks vs nulls
Discuss peaks vs nulls in the Equalization | Calibration forum; peaks vs nulls What type of items in a room cause peaks and nulls ? Which one of these graphs (different positions) would ...
Views: 637 - Replies: 17
Old 11-20-08, 01:29 PM   #1
Alias: Joe
Loc: Hartford, Ct
User: #14965
Since: Jan 2008
  jstefano is offline
peaks vs nulls
Which one of these graphs (different positions) would be best to start with ?
Name:  sub in corner.jpg
Name:  sub by rack.jpg
Old 11-20-08, 02:00 PM   #2
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is offline
Re: peaks vs nulls
Usually the major peaks and nulls in a room result from reinforcement or cancellation of freq's due to standing waves or room nodes. These are determined by the dimensions of your room and also the placement of the microphone and the speakers inside the room. I'm not particularily strong on this subject so maybe someone else will chime in.
The 2nd graph is a much better starting place.
Old 11-20-08, 03:01 PM   #3
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
Re: peaks vs nulls
You need to switch your graphs from linear to logarithmic. You may also want to contain all your questions in one thread so we do not have jump around to see how you are progressing. Just a thought.
Old 11-20-08, 05:15 PM   #4
Alias: Joe
Loc: Hartford, Ct
User: #14965
Since: Jan 2008
  jstefano is offline
Re: peaks vs nulls
What frequency's would I target if I want to decrease the "boomyness" of my sub ?
Old 11-20-08, 05:21 PM   #5
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
Re: peaks vs nulls
jstefano wrote: View Post
Looks like you have a major boost at 45Hz.
Old 11-20-08, 11:45 PM   #6
Alias: Steven
thewire's Avatar
Loc: Midwest
User: #9828
Since: Jun 2007
  thewire is offline
Re: peaks vs nulls
I like to deal with all of them, but I would recommend that you try and shoot for dealing with the lower fequencies and those possible peaks or dips. These are the lower room modes that can cause potential for coloration. Once you have delt with the axial (left to right, front to back, top, to bottom) room modes, the tangential room modes which are much lower in amplitude, tend to follow.
Old 11-21-08, 12:32 AM   #7
Alias: Steven
thewire's Avatar
Loc: Midwest
User: #9828
Since: Jun 2007
  thewire is offline
Re: peaks vs nulls
You can do an experement to demonstrate how having something in the room will change the measurement. Here a simple program I wrote that will do a left mouse click after around 15 seconds. Get the measurement window up in REW and point the arrow over the button to start the measurement and double click the file. Leave the room quickly moving away as far as you can, and wait for the measurement to occcur. Now do the same measurement again while you are at the computer. See how it is changed? You might need to look very close. This is just some practice and no need to post graphs. This should show that the measurement is sensitive to what is inside the room.
Old 11-21-08, 03:12 PM   #8
Alias: Joe
Loc: Hartford, Ct
User: #14965
Since: Jan 2008
  jstefano is offline
Questions
1. Jamo A340 Speaker freq range 50 Hz-20 kHz would you consider this a "Full range" or "Bass limited" ?
2. Denon 3806 AVR, if the crossover freq for the LFE is set at 80 Hz does it matter what the sub's crossover freq is set at ?
3. My AVR has an option for "LFE" or "LFE+MAINS" what would be the correct setting and what is the difference ?
4. Why don't you treat "Nulls" more aggressively with filters ?
5. If I want to run 2 subs do I split my LFE out from my AVR ?
Please see my signature for the list of my equipment
Thanks for your knowledge
Joe
My Equipment
Pioneer 150 FD PRO KURO 60" Plasma, Directv HR20 DVR, Denon 3806 AVR, Denon 2910 DVD, Panasonic BD30 BLU-RAY, Jamo 340 wall & stand speakers (7), Jamo 10" Sub. Polk Pro600 Sub
Calibration Equipment
Video: CalMAN software, ControlCAL software, i ONE PRO & Display 2 Meters.
Audio: EMC8000, RS digital SPL, XENYX 802, Soundblaster Live 24, RoomEQ software
Computer: DELL VOSTRO Laptop
Old 11-21-08, 03:25 PM   #9
Alias: brucek
User: #6
  brucek is online now
Re: peaks vs nulls
Bass limited. But all main speakers should be used as 'small' when it comes to bass management.
The subs own crossover should be disabled.
I believe this sends the LFE track to the mains. Best to send it to the sub.
Nulls are often created by a reflection arriving out of phase with the main signal and so causing a null. If you increase the level of the main signal with a filter, you will also increase the level of the out of phase signal. The result is that nothing changes. All you're doing is decreasing headroom. It doesn't work..
5. What would you do with this graph ?
Change the presentation to LOG from LIN as already suggested so we can better evaluate it.
Old 11-21-08, 03:47 PM   #10
Alias: Joe
Loc: Hartford, Ct
User: #14965
Since: Jan 2008
  jstefano is offline
Re: peaks vs nulls
Thanks for your input Bruce,
Here is the graph I would like some advice on, It is My sub and mains. I am just looking to see how you would interpret this graph.
Name:  friday polk.mdat.jpg
There is also a ? regarding 2 subs on the other post
I went to Tweeters today and bought a Polk Pro 500 Sub
Thanks again
My Equipment
Old 11-22-08, 09:42 AM   #11
Alias: Joe
Loc: Hartford, Ct
User: #14965
Since: Jan 2008
  jstefano is offline
My Media Room & Setup
Here are some Pic's of my room and calibration setup
Name:  Media Room 3.jpg
My Equipment
Old 11-22-08, 11:06 AM   #12
Alias: brucek
User: #6
Re: peaks vs nulls
Can we see the waterfall?
Use the standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - 200Hz) using the Graph Limits button in the top right corner of REW.
Set the mode to LOG rather than LIN using the Freq Axis button in the top right corner of REW.
Best to set the time range to 600msec and leave the Window at 300msec.
Set the X=1, Y=50, Z=150.
Select the measurement in the REW left pane you want to look at, and Generate the waterfall.
Old 11-22-08, 12:57 PM   #13
Alias: Joe
Loc: Hartford, Ct
User: #14965
Since: Jan 2008
  jstefano is offline
Waterfall
Here you go.
I also want to know the best way to hook 2 subs to my BFD. Is it ok to split the LFE output of my AVR and run 1 sub on the Lch and 1 sub on the Rch of the BFD ?
My Equipment
Old 11-22-08, 11:49 PM   #14
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: peaks vs nulls
A couple of things. I once tried experimenting with various placement options with two subs in a rectangular room, and I got the absolute worse results with them catty-cornered like you have in your picture above. Most of the time the best approach is use REW to find the best location, and put both subs together there.
Second, it's usually not a good idea to use mismatched subs. Typically what you'll find is that the weaker one will "dumb down" overall performance (to use a great phrase brucek coined).
Old 11-25-08, 03:02 PM   #15
Alias: Joe
Loc: Hartford, Ct
User: #14965
Since: Jan 2008
  jstefano is offline
Re: peaks vs nulls
If my LFE crossover is set at 80 Hz do I need to filter this peak at 115 Hz ? and how does the rest look ?
Name:  tues both sw.jpg
My Equipment
Old 11-25-08, 03:15 PM   #16
Alias: brucek
User: #6
Re: peaks vs nulls
Normally, you would add the mains and see how that transition area looks before you tackle the peak at 115Hz.
Old 11-25-08, 04:13 PM   #17
Alias: Joe
Loc: Hartford, Ct
User: #14965
Since: Jan 2008
  jstefano is offline
Re: peaks vs nulls
Here is the mains added
Name:  tues with mains.jpg
My Equipment
Old 11-26-08, 09:32 AM   #18
Alias: brucek
User: #6
Re: peaks vs nulls
Looks fine.....
nulls, peaks
