| REW Forum REW setup with Protools HD systemDiscuss REW setup with Protools HD system in the Equalization | Calibration forum; REW setup with Protools HD system Has anyone here successfully used REW with a Protools HD rig?
here's my setup:
Mac Intel Xeon 2.33 Quad core ... |
Views: 911 - Replies: 6
| REW setup with Protools HD system Has anyone here successfully used REW with a Protools HD rig? here's my setup: Mac Intel Xeon 2.33 Quad core (running Tiger) Protools HD2 with a 192 i/o I downloaded the REW for Mac and loaded it into the sytem. When I go to setup the soundcard, I can get the calibration sound as well as the test tone sound to come through the speakers (I selected the Core Audio output and 44.1k for the input, for the output, my only choice is Default). I plugged a pic into a pre into the first channel of my 192. I can see the mic picking up signal in the preamp as well as in the 192 input channel 1. however, although REW can create the test tone through the speaker, the microphone setup doesn't pick up anything. when I go to "test connection" after the calibration it says the input is too low to work and I get no reading/analysis. When I'm looking at the meter, I see the signal on the left mono meter at -12 and hear the test tone, but am getting nothing on the right stereo meter. I have tried everything including switchign the input from left to right, etc. I'm assumign its working somewhat if i can hear the tone through the speakers, but the input part doesn't seem to work, can anyone help me here? Thanks, Doug at Rough Magic Studios brooklyn, Ny | ||||
| | #2 | |||||
| Re: REW setup with Protools HD system Quote:
brucek | |||||
| | #3 | ||||
| Re: REW setup with Protools HD system Worth checking whether REW is being fed the signal from the built-in audio, or whatever is set as the default in the audio preferences. | ||||
| | #4 | ||||
| Re: REW setup with Protools HD system I would also like to know the answer to this question (I didn't see one in the replies below). If it is in the affirmative, please direct to any guide/instructions. I am seeing (in WinXP) ~> ![]() But no option to select in REW: ![]() Thanks in advance. ~Paje | ||||
| | #5 | ||||
| Re: REW setup with Protools HD system You would need WDM drivers for REW to be able to access the interfaces. For room measurements you would get perfectly adequate results using the integrated soundcard. | ||||
| | #6 | |||||
![]() My sound card speakers are not of the same quality & I don't have a mini-port mic of any quality at all. I'm trying to avoid having to buy an additional mic just for this sole, one-time application. I'll figure it out one way or another. ![]() Cheers, Paje | |||||
| | #7 | ||||
| Re: REW setup with Protools HD system You don't need (or want!) to use your soundcard speakers, you could patch your onboard soundcard line out to your mixer and route it to your monitors when you want to measure, similarly take a monitor feed from your mixer when using the mic input and connect it to your onboard line in. | ||||
