| REW Forum First Measurement. Ideas?Discuss First Measurement. Ideas? in the Equalization | Calibration forum; First Measurement. Ideas? First try of studio monitor in my small room. 11x17. Event ASP6. Any thoughts on tuning my measureing is appreciated.... |
Views: 951 - Replies: 24
| | #2 | ||||
| Re: First Measurement. Ideas? Well, this is an full range active studio monitor that claims +/- 3db 40hz-20KHz and it looks like it's doing the job. The only effect you can have with these is to provide some room treatment if you're not pleased with the lower end response. Certainly you would not introduce any equalization with an active main. What sort of ideas are you looking for? brucek | ||||
| | #3 | ||||
| Re: First Measurement. Ideas? Bruce, Thanks for the quick reply! This is a new graph with the studio door closed! The range has been expanded to 500hz. The monitors have been moved forward a bit and closer in. The mixes do not translate when moved outside of the studio. The bass is incorrectly heard in the mix leading to loss of bass when played away from the monitors. | ||||
| | #4 | ||||
| Re: First Measurement. Ideas? I'm afraid I know very little about recording studios. The response of your monitors looks not bad, although the room is causing a fair dip in the 70Hz-100Hz range. That's an area where a lot of bass energy is. In a studio you're listening near-field usually. A change in the overall sound is expected when listening outside the studio for that reason (I would assume). You can turn on the trace-smoothing of REW to smooth the sharp jumps in the graph. These sharp spikes are usually inaudible. brucek | ||||
| | #5 | ||||
| Re: First Measurement. Ideas? The room treatment is about as far as I'm going to go with it. The problem is the size of the room, which I can' t change. I get the idea the BFD is used usually to decrease peaks and not increase dips. I'm looking to smooth response. Doug, the creator of EFT's view is that electronic equalization after attempting room treatment is OK when applied sparingly. I would agree with that. Bad monitors generally can't be made into good ones with EQ, but good ones may be helped to improve the overall listening experience of the room. How is it you can see the room response along with the speaker? I understand it is in the graph, just don't understand the difference. Will I be able to, in your opinion, use BFD to correct room problems? Thanks | ||||
| | #7 | |||||||
| Re: First Measurement. Ideas? Quote:
But, and this is a big but, I would never use a BFD for full range duties. It will simply add too much noise. I have both personal and anecdotal evidence of this. It is not studio quality. Its use is restricted to subwoofer duties where the noise is inaudible. I agree with Doug. Room treatment is your first avenue. I thought any EQ in a studio environment was considered bad form? Quote:
Usually anechoic speaker response is published - that should give you a better idea of what your speakers are capable of without room influence. There is a way of checking your speakers reflection free response with REW, but it severely limits the low frequencies in the response result - so that's not an option, but some people do a near-field response of their speaker outside to get a quasi-anechoic response. Quote:
I think you're being kind to yourself using the vertical scale from 30Hz-105Hz. You might expand that to 45Hz-105Hz. The graph of course will look worse. You might modify your horizontal scale to start at ~30Hz. You aren't measuring a subwoofer, so the 15Hz you're using is too low. I trust you're using the correct microphone calibration file and you've calibrated your soundcard... brucek | |||||||
| | #8 | ||||
| Re: First Measurement. Ideas? Speaker correction vs room correction is a sticky subject. When faced with a situation such as mine, small amounts of speaker correction is OK. It's about the ability to take great sounding mixes from the studio environment and have great sounding mixes in your car, home, computer, iPod.etc. I know the quality of these speakers is high, and yes, the curves in a chamber are very flat. So now I understand room curve vs the speaker curve! I am mainly interested in the low end response, so BFD will be useful. Doug(EFT) reccomends it's use also. I'm going to try different speaker locations and listening positions to check for the effects of room modes on the REW graphs. It didn't appear that moving the mic faced towards the speaker or towards the ceiling made any huge change in frequency response. I would think moving forward and back in this small room could change freq. readings. I do indeed have the calibration files for my mic loaded and have calibrated my sound card. I'll read the sticky as suggested and change my scaling. Thanks | ||||
| | #10 | ||||
| Re: First Measurement. Ideas? The after looks quite good. How are you integrating the BFD (if that's what you used) into the system? Is the entire full range signal passing through it or have you broken-out the woofer signal before the speakers amp somehow. Either way, how does it sound? Is there any additional noise associated with the after EQ result? You're down about 10dB at 40Hz, so not too bad. Does the bass sound OK? ![]() brucek | ||||
| | #11 | |||||
| Re: First Measurement. Ideas? Ross, Welcome to the Forum! Quote:
I assume you’re in smallish room? The problem is that most rooms, especially symmetrical rooms (i.e., square or shoebox dimensions) have a null area or “bass hole” in the dead center. From there, the closer you move to any boundary, the more perceived bass intensity increases. With a small room, you probably have your desk against a wall, or close to it. By the time you add the width of the desk and another few feet to where you’re head is, you’re pretty close to the center of the room – right smack in the middle of that “bass hole.” To confirm this, do this simple test: Play some music and leave your chair and move towards a wall or a corner. I’ll bet you’ll find the bass level increasing the closer you get to a boundary. The other problem is that small studio monitors deliver small bass. It’s extremely difficult to take a mix from them to a home system with even a modest subwoofer. Same with a decent car audio system. Your EQ’d response is nice and flat now, and I’ll bet it sounds really thin, if not shrill. I mean, you’ve got something like a 30-dB drop between 70 and 30 Hz! You probably need at least an 8 dB or more rise in response across that range – i.e., a house curve. You might want to check the house curve sticky thread on this forum’s index page. Bottom line, add a subwoofer and you have a much better chance of getting a mix that will play well outside the studio. That won’t fix the “bass hole” problem – you’ll just have to optimize response for the listening position. And, I echo brucek’s recommendation not to use the BFD for the mains. Sticking a $100 equalizer on a $1000 set of speakers is just wrong, especially if the problem you’re having is all in the bass region. Get a sub and you can equalize it with the BFD, and keep your mains free of extraneous processing. Regards, Wayne | |||||
| | #12 | ||||
| Re: First Measurement. Ideas? Bruce, the sound is not effected to great extent. A bit smoother I would guess. I'll have to see in a few days. 5 hours today was about as much as I could take. The speaker is not broken into separate components, so all frequencies pass through. The filter around 480 is pushed up to high and I think is causing distortion. I may reduce or eliminate this filter. I have to confess that I realized when looking at the back of one of the monitors that I had in the past jacked up the low end compensation 3db in an attempt to get better bass response!! This would lead me to mixes that would actually not have enough bass!! I'm going to try a short mix with the new EQ and see how it sounds in the outside world. | ||||
| | #13 | ||||
| Re: First Measurement. Ideas? Wayne, thanks for the insight and concern! My mix postion is about 6.5 ft off the front wall and the monitors are about 2.5 feet off the front wall. I moved them about using REW till I acheived the best-smoothest bass response. Then I filtered. I have many bass traps suspended which has helped tremendously to balance bass response thoughout the room, so as not to have much bass buildup. I am concerned about the rolloff from 55hz down. I'm sure the Events do not drop off at this rate. Could this be a function of the room? Bottom line, add a subwoofer and you have a much better chance of getting a mix that will play well outside the studio. That won’t fix the “bass hole” problem – you’ll just have to optimize response for the listening position. I'd also like to say that I have less concern about the use of subs in the general public and feel they are not as common as 2.0 stereo, so I'm less inclined to add a sub to my system. Music is being mixed with lower freqs because the ability to reproduce them is easier for the general listener's stereo. Are you saying that a sub will fill this space and when REW/BFD'd will better serve the overall sound? If so, I might try one. Any you'd recommend? I'm attaching the Events freq response chart to take a look at. | ||||
| | #14 | ||||||||
Regards, Wayne | ||||||||
| | #15 | ||||
| Re: First Measurement. Ideas? I sent an email to Bruce comcerning the fact that I'm using the oldest RS mic and the cal file I've used is for the one that came out after mine!! This is one reason the bass response has such a severe rolloff. I don't know if the correct file is available anywhere or if I'm going to have to buy another mic before proceding!! Your assumption about post mixs being overly bassy make sense when looking at the current graphs. Actually they tend to be light on the bass. I'll have to redue after fixing the mike problem. Any ideas on a reasonable mic or should I buy a RS again? I would think the info concerning buying a sub still is valid and yes there are a couple pro audio units availble for not a lot of cash that will have the balanced input. They are also self powered, around $300. | ||||
| | #16 | ||||
| Re: First Measurement. Ideas? I believe there were only three RS type meters ever made. The original (old) meter was around for a long time and then they updated it and also started selling a digital one. The three calibration files are available here. What cal file were you using? brucek EDIT post: OK, on further investigation after remembering that there was a meter #42-3019 that we didn't think was around any more, I found the supposed calibration file for it. This calibration file, wasn't very resolute and had been kicking around the internet for many years. I can't vouch for its accuracy since we only used the three meters listed above for our tests. Sonnie used his professionally calibrated ECM8000 to establish the cal files for the three listed and never tested the 42-3019. Here's the file for the #42-3019 that I had on file and also found on the internet. Just copy the contents to notepad and save as RS.cal RS.cal Code: 10.000 -20.000 0.000 12.500 -16.500 0.000 16.000 -11.500 0.000 20.000 -7.500 0.000 25.000 -5.000 0.000 31.500 -3.000 0.000 40.000 -2.500 0.000 50.000 -1.500 0.000 63.000 -1.500 0.000 80.000 -1.500 0.000 100.000 -2.000 0.000 125.000 -0.500 0.000 160.000 0.500 0.000 200.000 0.500 0.000 250.000 -0.500 0.000 315.000 0.500 0.000 400.000 0.000 0.000 brucek | ||||
| | #18 | |||||
![]() Nice to get a new meter though.... brucek | |||||
| | #19 | ||||
| Re: First Measurement. Ideas? If nothing else having two SPL meters give one the option of eliminating the meter as the culprit when a problem like your rapid bass rolloff crops up under test. I have hoped for the last 15 years that my SPL meter would turn out to be perfectly flat when tested against another. No other response ever made any sense when my sub shows a +30dB house curve to 15Hz at the listening position! I had exactly the same problem with my previous DIY bandpass boxes in an even larger listening space. ![]() I'm tempted by one of the new soft-look analogue meters myself. ![]() | ||||
| | #22 | ||||
| Re: First Measurement. Ideas? Hey! This a new graph with the sub added as Wayne had suggested to even the bottom out and boy did it! It's a KRK 10s 10" w/ 200 watts. It has a variable LF cutoff from 50-130hz. There's also a nasty dip at about 75 hz that I'm BFDing out of there. Is this a crossover problem? Take a look. | ||||
| | #23 | ||||
| Re: First Measurement. Ideas? Looks good, with much better low end extension. Most people prefer their sub a bit hotter than the mains though. If you turned the sub amplifier up a bit and then added a house curve by slowly cutting from about 40hz down to the crossover, you might like the sound even better.... You should read Waynes sticky on house curves......... brucek | ||||
| | #24 | |||||
| Re: First Measurement. Ideas? Big improvement! Bet is sounds better, too. ![]() Quote:
| | #25 | ||||
| Re: First Measurement. Ideas? Yes, it's very smooth. It's taking a bit to get used to it! The 75 hz dip has been there all along. I'm going to try some different listening position tests to see if it persists or not. I do have two filters assigned to it already.I'll check the House curve blip. Bruce you say to add a filter curve from 40hz to crossover? I best read the article first! | ||||
