REW Forum
REW Results.. Thoughts?
Discuss REW Results.. Thoughts? in the Equalization | Calibration forum; REW Results.. Thoughts? Sub Only... Sub and left speaker 80hz, phase 0 deg Final.. Sub crossed at 80hz, phase 45 deg, LFE trim ...
Views: 394 - Replies: 5
Old 11-26-08, 04:45 PM   #1
Alias: Tony
User: #23602
Since: Jul 2008
  adidino is offline
Sub Only...
Final.. Sub crossed at 80hz, phase 45 deg, LFE trim -3db
Old 11-26-08, 06:23 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: REW Results.. Thoughts?
For subwoofers, always use the standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - 200Hz) using the Graph Limits button in the top right corner of REW.
Old 11-26-08, 06:27 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Any other placement options you can try to help eliminate that big hole between 35-45 Hz?
Old 11-26-08, 06:43 PM   #4
Alias: Tony
User: #23602
Since: Jul 2008
  adidino is offline
I'm sort of limited to the front stage or the back of the room. I'll try moving it from the right side of the room to the left and see if that helps. If not, maybe the back of the room? I'm also thinking some bass traps in the front corners of the room may help that. How about the rest of the freq spectrum?
Old 11-27-08, 01:20 PM   #5
Alias: Wayne
Loc: Katy, Texas
User: #8
Looks fine...
Old 11-27-08, 01:37 PM   #6
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
  atledreier is offline
My two subs go to the back of the room every time. I've tried 'everywhere', and the only place they really work is in the back.... As long as they are symetric localization is not an issue.
results.., thoughts?
