REW Forum
Help with 130hz peak
Discuss Help with 130hz peak in the Equalization | Calibration forum; Help with 130hz peak I'm finally in my room was wondering if anybody has any idea what could be done to improve the peak ...
Views: 479 - Replies: 6
Old 12-02-08, 05:59 PM   #1
Alias: peteys
User: #26838
Since: Oct 2008
  peteys1 is offline
I'm finally in my room was wondering if anybody has any idea what could be done to improve the peak I've got. I've got the room trapped and positioned but no matter what I do I can't seem to improve this peak. These are for a recording studio environment and the dimensions are 23 by 34 with an 8 foot ceiling.
I'm extremely happy with how it sounds. Thanks to the RTA feature in REW. It has taken me hours and hours but it sounds really good and the graph isn't that bad, but I just want to see if I can get it better.
Old 12-02-08, 07:08 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Help with 130hz peak
Since it appears you've done all you can with positioning, that pretty much leaves using a good-quality parametric EQ as your only option.
Old 12-05-08, 06:25 PM   #3
Alias: peteys
User: #26838
Since: Oct 2008
  peteys1 is offline
I've repositioned my system to a corner and the response has improved the peak at 130. Do you think these graphs look better than the previous ones? I know this isn't the place normally to put speakers but the graph does appear better except for the dips below 60 hz. The speakers only go to 42 hz as per the manufacturer.
Old 12-05-08, 07:28 PM   #4
Alias: brucek
User: #6
  brucek is online now
Looks quite good..............
Old 12-05-08, 09:09 PM   #5
Alias: Wayne
Loc: Katy, Texas
User: #8
Yes, it looks really good! However, it might sound overly bright, what with the bass response gradually descending like that. If you find that's the case, your basic tone controls can take care of it.
Old 12-06-08, 04:54 PM   #6
Alias: peteys
User: #26838
Since: Oct 2008
  peteys1 is offline
It doesn't sound too bright. Do you think I should be concerned with the ringing in the water fall graph, though? The waterfall looked better when the desk was in the middle of the room. Most of the ringing was gone below 40 hz. Not so, in it's present position in the corner. Kind of strange that there are even frequency's registering that low since the speakers roll off at 42 hz. What do you guys think?
Old 12-06-08, 10:01 PM   #7
Alias: Wayne
Loc: Katy, Texas
User: #8
Hard to say about the ringing. You might want to float the question over at our Acoustics Forum - you'll get a better-informed response there.
130hz, peak
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
