REW-graph for SVS PB12 Plus/2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss REW-graph for SVS PB12 Plus/2 in the Subwoofer Equalization | Calibration forum; REW-graph for SVS PB12 Plus/2 I've attached a chart showing how my SVS PB12 Plus/2 responds in my listening room. I have the sub tuned ...
Old 04-30-06, 11:01 AM   #1 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
I've attached a chart showing how my SVS PB12 Plus/2 responds in my listening room. I have the sub tuned to 20Hz with one port blocked.
Old 04-30-06, 02:04 PM   #2 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
Re: REW-graph for SVS PB12 Plus/2
Below are the manufacturers curves:
http://www.svsound.com/products-sub-box-plus2.cfm#curve
Ron Carlton
Dallas, Texas
Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo DV-981HD, Toshiba HD-A2, Cambridge Audio Azur 640C, Belkin Pure AV PF60, Behringer DSP1124P
Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Denon DVD-2200, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro
Old 04-30-06, 08:12 PM   #3 (Link)
Loc: Lower Alabama
Sonnie is offline
heh... those manufacturers response charts are nearfield measurements and probably performed in a wide open area or either in an anechoic chamber set up for such measurements.
Do you have a BFD? You can fix that right up. You may not be able to do as much with that peak at 19hz without having to fiddle with some serious offsetting boosted filters from 25-30hz. You could however, tune your sub port to 22hz and that might tame it. Or if you are able, move the sub out from the wall a little more. Looks like you got some good room help down low there.
I love this sub... I've got two of 'em.
Sonnie
Old 04-30-06, 09:56 PM   #4 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
No BFD yet . I am using the built in Parametric EQ for the peak around 40 Hz.
I also need to construct some bass traps...I have 18' ceiling and only a 12' ladder.
Ron Carlton
Dallas, Texas
Old 04-30-06, 10:24 PM   #5 (Link)
Loc: Lower Alabama
Sonnie is offline
You'll need some serious bass traps to trap those frequencies that low. Could be a challenge.
18' ceiling
Sonnie
Old 04-30-06, 10:43 PM   #6 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
Tried different port settings:
green=16Hz
purple=20Hz
red=25 Hz
Ron Carlton
Dallas, Texas
Old 04-30-06, 10:46 PM   #7 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
Here is a chart with the main speakers included. Tuned to 20Hz.
Ron Carlton
Dallas, Texas
Old 04-30-06, 10:54 PM   #8 (Link)
Shack City Slicker
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
I was always under the impression that basstraps were more effective in frequencies an octave or two above the range of a subwoofers output. Id definitely play with phase and location (as sonnie suggested) if possible to try and iron out any cancellation that may be going on first. Then tweak flat with the BFD. my.02
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Old 04-30-06, 11:05 PM   #9 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
I only have 3 possible locations for the sub. Unfortunately, I have the computer in one of them. The sub is not too difficult to move if I drag it with a blanket ...it weighs 160 pounds. I'll try to get measurements in all three locations and compare. Finding the best location for the sub should be step one, can't change the location of the mains. I'll play with the phase some more.
Ron Carlton
Dallas, Texas
Old 04-30-06, 11:16 PM   #10 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
If/when I get a BFD, do I turn off the parametric equalizer built in to the sub (only handles 1 peak) and use the BFD exclusively (seems like the right thing to do)? Or do I use them together?
Ron Carlton
Dallas, Texas
Old 05-01-06, 12:18 AM   #11 (Link)
Loc: Lower Alabama
Sonnie is offline
Generally 80hz and above, unless you are willing to get serious big and bulky... and do a lot of experimenting.
You shouldn't need the one on the sub. You got up to 24 on the BFD, which I'd think you could do what you need to do with 12 filters or less.
Sonnie
Old 05-01-06, 11:54 AM   #12 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
Sonnie,
It might be easier to use the built in equalizer to tame the peak at 19 Hz, and allow the BFD to take care of the others.
Ron Carlton
Dallas, Texas
Old 05-01-06, 01:10 PM   #13 (Link)
Loc: Lower Alabama
Sonnie is offline
True! I'm not familiar with the built-in peq on the SVS since mine does not have it. If it will handle below 20hz then I'd say that is a good thing and will work for you well.
Sonnie
Old 05-01-06, 02:18 PM   #14 (Link)
Alias: brucek
User: #6
brucek is offline
Yeah, I see no problem with that.......
Old 05-13-06, 01:48 PM   #15 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
I moved the sub to the right rear of the room. Curve looks a little better.
Ron Carlton
Dallas, Texas
Last edited by rcarlton; 05-13-06 at 09:15 PM. Reason: Adjusted scale of chart, removed RS SPL corrections.
Old 05-13-06, 02:37 PM   #16 (Link)
Alias: brucek
User: #6
brucek is offline
Unfortunately, you're using the incorrect newrs.cal file for your Radio Shack meter. The file you're using got onto our server by mistake and a few people downloaded it before we found the problem.
Reload the correct file here.
You shouldn't have to remeasure if you've saved your mdat files and filter files. It will make a difference to the graph though.. Sorry.
Also note this info about graph axis limits.
Old 05-13-06, 09:06 PM   #17 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
It appears that I cannot download the newrs.cal file now. Also the images for the graphs are nice little red x's.
Ron Carlton
Dallas, Texas
Old 05-13-06, 09:23 PM   #18 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
This graph shows how the sub interacts with the mains.
Ron Carlton
Dallas, Texas
Old 05-14-06, 12:23 AM   #19 (Link)
Loc: Lower Alabama
Sonnie is offline
Are you still seeing little red x's?
I see the images fine and when I click on newrs.cal I get ask whether to open or download when using IE. FF opens it unless I right click and select save link as to download it.
Sonnie
Old 05-14-06, 07:06 AM   #20 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
I get the little red x's when using IE. Nothing shows up with Opera or Firefox.
Cannot download the file in any of the browsers. Get a message saying:
This file or image is protected.
You may be required to be registered and logged in at Home Theater Shack in order to view the file or image.
If you would other wise like permission to use this link, please send an email to:
webmaster@hometheatershack.com
I'm registered and logged in...otherwise I couldn't post.
Ron Carlton
Dallas, Texas
Old 05-14-06, 07:16 AM   #21 (Link)
Alias: brucek
User: #6
brucek is offline
Weird?
Anyway, heres the file. Copy it into a notepad file and rename it newrs.cal and save
Code:
10 -27.00
11 -24.15
12 -21.91
13 -20.13
14 -18.61
15 -17.33
16 -16.15
17 -14.92
18 -13.85
19 -13.01
20 -12.38
21 -11.66
22 -10.79
23 -10.00
24 -9.33
25 -8.80
26 -8.41
27 -7.99
28 -7.50
29 -6.99
30 -6.50
31 -6.03
32 -5.60
33 -5.23
34 -4.89
35 -4.58
36 -4.29
37 -4.04
38 -3.83
39 -3.64
40 -3.46
41 -3.31
42 -3.16
43 -3.01
44 -2.88
45 -2.74
46 -2.60
47 -2.46
48 -2.35
49 -2.26
50 -2.21
51 -2.18
52 -2.15
53 -2.11
54 -2.04
55 -1.98
56 -1.95
57 -1.92
58 -1.88
59 -1.84
60 -1.80
61 -1.77
62 -1.73
63 -1.71
64 -1.71
65 -1.72
66 -1.70
67 -1.67
68 -1.64
69 -1.60
70 -1.56
71 -1.52
72 -1.47
73 -1.41
74 -1.34
75 -1.26
76 -1.19
77 -1.12
78 -1.07
79 -1.02
80 -0.98
81 -0.94
82 -0.89
83 -0.85
84 -0.80
85 -0.75
86 -0.71
87 -0.66
88 -0.62
89 -0.59
90 -0.55
91 -0.52
92 -0.50
93 -0.47
94 -0.43
95 -0.40
96 -0.36
97 -0.34
98 -0.32
99 -0.30
100 -0.27
101 -0.25
102 -0.23
103 -0.20
104 -0.17
105 -0.14
106 -0.11
107 -0.07
108 -0.03
Old 05-14-06, 07:35 AM   #22 (Link)
