REW Forum
Java update causing headaches!
Discuss Java update causing headaches! in the Equalization | Calibration forum; Java update causing headaches! I installed an update for Java and now none of my measurements will show up in REW. They show up ...
Views: 403 - Replies: 6
Old 12-02-08, 11:23 PM   #1
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is offline
Exclamation Java update causing headaches!
I installed an update for Java and now none of my measurements will show up in REW. They show up when I manually browse to them but when I try to open them through REW the folders are empty and none of my measurement files show up. Has anyone else experienced this? I've got a bunch of information that I'd hate to not have access to and I need to get this fixed. I'm running Vista Ultimate 32bit.
Old 12-03-08, 08:38 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Java update causing headaches!
Yeah, interesting question. When another member asked this question last week I tested my two machines with REW and it worked fine on XP SP3 and Vista Premium 32 bit.
But then, the same day (on my main XP computer) I was using my investment software that utilizes Java for its graphs and the software itself worked fine, but all the graphs were missing.
I decided to roll back the Java version from the recently installed Version 6 Update 10 to the last Version 6 Update 7, and everything was fine again. So, I re-installed Update 10 and it failed to display the graphs, so I left Update 7 in that XP machine.
I then tested the graphing software with Update 10 on the Vista machine and it was OK, so go figure. So, it appears there is at least something amiss with the new Update 10.
I suspect there will be enough complaints and it will be cleared up. Until then, I have no problem with using Update 7 on my XP machine.
So, if you want to roll back the version:
1. Open the Windows control panel and select Java. On the General tab you can view the Version by clicking About. It will say Version 6 Update 10.
2. Now select the Update tab and unclick the automatic updates. (you'll be able to recheck it at a later date and also be able to click the Update Now to return to the latest version).
3. Re-Open the Windows control panel and select Add or Remove Programs. Scroll down and select Java 6 Update 10 and click Remove.
Now when you check the version it should say Update 7.
Try REW and see if it's OK.....
I'll alert John about this problem and see if he has any ideas...
Old 12-03-08, 10:30 AM   #3
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Java Update 10 includes very extensive changes to the graphics rendering pipelines, with Direct3D no longer supported on many older hardware platforms, which may be part of the problem. I'll do some investigating this weekend but it is unlikely that I will be able to resolve the issues within REW, may need to stick with update 7 or wait for update 11.
Edit: More info about update 10 here: Update 10 release notes. Note the encouragement to ensure you have the latest drivers for your graphics card.
Old 12-03-08, 02:44 PM   #4
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is offline
I fixed my issues last night. I went into the folders containing my measurements and cut them all out and pasted them into a new directory and group of folders that I created. Lo and behold this worked. I don't know why, but after I moved them this way REW is seeing them again. I wasn't having a problem creating new measurements after I updated only using the old ones. I have no idea why that would've worked but I'm not second guessing.
I also had a strange problem with trying to create a new cal fil after the update. I don't remember exactly what it said in the pop-up but it was denying the creation of the file. I'll see if that is still a problem tonight. That was how I originally noticed something was amiss was my main cal file was missing, so I tried to create a new one.
Old 12-09-08, 02:43 PM   #5
Alias: brucek
User: #6
If anyone has REW problems with the latest Java update 10 or 11, they might also try a fix that works with other software I was having trouble with after the latest update.
Open the Windows control panel and double click Java to bring up the Java Control Panel, and then select the Advanced tab. Then open the Java plug-in selection, and uncheck the Enable next generation Java plug-in box.
Then you'll need to restart your computer.
This may help, since it was the fix for problems I was having with other software that uses Java.
See here for an explaination of what this checkbox does.....
Old 12-10-08, 08:15 PM   #6
Alias: Steven
thewire's Avatar
Loc: Midwest
User: #9828
Since: Jun 2007
  thewire is offline
Is it safer to not update Java? Mine has been asking to update since the day after this thread started.
Old 12-11-08, 07:56 AM   #7
Alias: brucek
User: #6
I would say it's safer to install the update, if your applications work with the update.
The updates increase your security, so it's wise to install them if you can....
Simply install it and see if your software works. If not, revert back..
causing, headaches!, java, update
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
