REW Forum
First time running REW
Discuss First time running REW in the Equalization | Calibration forum; First time running REW Hello All, I played around with REW for a couple of hours and can't seem to get the measurements to ...
Views: 343 - Replies: 1
Old 12-06-08, 12:16 PM   #1
New Member
Alias: tdragon
Loc: Marysville, WA
User: #29308
Since: Nov 2008
  twindragon is offline
Hello All, I played around with REW for a couple of hours and can't seem to get the measurements to smooth out. Attached is the measurements of both my subs together hooked up to only one channel of the BFD, but in BYPASS mode (no filter). How does it look? Is it pretty bad? Now if the subs are only going to be playing frequencies 80hz and lower, do we need to set the end frequencies out to 200hz or will setting it to 80hz is okay? Another question, I've read about calibration files for the radio shack SPL meter (model 33-4050), okay, I see it and downloaded it, but haven't done anything with it. Where do I enter the compensation value? Or do I need it at all? Thought I read it somewhere that you don't need it if you're using REW to take your measurements, but can't remember where I read it or was it just part of my imagination and confusion from all the readings. Also, we only have 12 filters to play with per channel if we're only using either the left or the right channel, correct?
Thanks, TwinDragon
Old 12-06-08, 12:49 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: First time running REW
Yes, you need the end frequency to be 200Hz. The crossover setting of 80Hz isn't a brick wall. You can see how the sub show trail off by observing the target line on the graph for 80Hz (presuming that you have it set at 80Hz). If the sub doesn't track the target line, then the mains may not mix properly over the crossover area.
Be sure you're running REW through your receiver with the crossovers set.
The Meter calibration file is pointed to in REW by browsing to the file location on the Settings page.
The file is very much needed....
12 filters for each channel of the BFD.
Hopefully you have read and are familiar with the REW HELP files.
running, time
