REW Forum
My sub repsonse graphs
Discuss My sub repsonse graphs in the Equalization | Calibration forum; My sub repsonse graphs Here is my final low end response! It consists of 2 seperate 12" band-pass boxes, that are EQ'd using a ...
Views: 411 - Replies: 10
Old 12-13-08, 10:30 AM   #1
Alias: avnewbie
User: #20434
Since: May 2008
  AVnewbie is offline
Here is my final low end response! It consists of 2 seperate 12" band-pass boxes, that are EQ'd using a FBQ2496.
The first image has 1/3 octive filtering and the other has no filtering.
any comments?
Old 12-13-08, 12:21 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: My sub repsonse graphs
Not much to say other than the response is really good.
Can we see the waterfall (using the same scaling)?
Old 12-13-08, 05:17 PM   #3
Alias: avnewbie
User: #20434
Since: May 2008
  AVnewbie is offline
Here is the waterfall. I don't fully understand it!
Old 12-13-08, 05:50 PM   #4
Alias: avnewbie
User: #20434
Since: May 2008
  AVnewbie is offline
Here is a better waterfall with proper graph settings.
Name:  sub response waterfall log.jpg
Old 12-13-08, 06:31 PM   #5
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Just out of curiosity ...Can you post the graph with EQ'ing???
Old 12-13-08, 06:47 PM   #6
Alias: brucek
User: #6
Looks very good. You do have some ringing out at very low frequency <20Hz, but I don't think it will cause much trouble...
Old 12-13-08, 07:37 PM   #7
Alias: avnewbie
User: #20434
Since: May 2008
  AVnewbie is offline
Salvasal
Here is my original sweep with no EQ'ing (Green trace) the blue trace is the PEQ filters i applied to get the traces from above.
Is that what were interested in seeing?
Old 12-13-08, 07:40 PM   #8
Alias: Tim
OvalNut's Avatar
Loc: North of Atlanta, GA
User: #1625
  OvalNut is online now
That waterfall, and the frequency response, look wonderful. Well done!
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
Old 12-13-08, 07:56 PM   #9
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
AVnewbie wrote: View Post
Thank you, that's what I wanted to see.
I will work on my sub response this weekend and I wanted to see the difference between graphs ... in your case the results are excellent .
Old 12-14-08, 12:40 PM   #10
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is offline
Are you boosting 8-13db between 15-25hz? Looks like about 13db at 20hz. That's a lot of boost.
Old 12-14-08, 03:50 PM   #11
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Wow, that's some pretty severe equalizing...
Looks like you have ~15 dB boost at 20 Hz? Plus a lot in the 50 Hz and 90 Hz regions? Plus some extremely narrow filters, which seldom offer any benefit. With that much equalizing, especially down low, I hope your system has enough headroom to handle it...
Your baseline graph shows fairly severe deviation between the peaks and valleys. It would be best to find another location that would give a better baseline that would facilite less severe equalizing. Also, I see you've equalized all the way up to 150 Hz or so. There's usually no reason to equalize above the crossover point.
On the plus side, your waterfall looks really good. If nothing else it offers evidence that boosting filters don't result in increased ringing! You might want to take a look at it with a 300 ms window.
graphs, repsonse
