how to measure the effects of diffusers - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #11 of 15 Old 06-05-16, 08:02 AM Thread Starter
djnagle's Avatar
Re: how to measure the effects of diffusers
I am new to REW Les. I've used it a number of times but not with any real deep understanding of the program. Will the reflections show up as the deep dips when I set it to 48 smoothing?
djnagle is offline
post #12 of 15 Old 06-05-16, 09:45 AM
lesmor
djnagle wrote: View Post
Hi
I am reasonably new to REW as well but if you use the help option and search for impulse response you will see ETC mentioned.
I would suggest visiting AVS find the REW thread, look for a post from Austin Jerry in his sig is an excellent guide on using REW.
Near the end is a section on impulse response and ETC showing how to identify reflections.
I imagine if you use that before and then after fitting your diffusers it might help in showing the effectiveness of your experiment.
Good luck with your project and I hope it works out for you
lesmor is offline
post #13 of 15 Old 06-05-16, 05:57 PM Thread Starter
djnagle's Avatar
Thanks for the tip Les, I'll check it out tonight. I had every plan of doing this today, but very heavy rain, lightning, and thunder pushed back my yard work. I have the wood, pattern template, and band saw so it shouldn't take long to make and install them. I use clamps first and if they do make a difference, I screw them. Pix coming.
lesmor likes this.
djnagle is offline
post #14 of 15 Old 06-16-16, 05:46 PM
Blacklightning's Avatar
Any update?
Blacklightning is offline
post #15 of 15 Old 08-09-16, 02:41 PM Thread Starter
djnagle's Avatar
No update. Summer got in the way.
djnagle is offline
diffusers , effects , measure
