REW Forum
Reverberation time ?
Discuss Reverberation time ? in the Equalization | Calibration forum; Reverberation time ? Hello, I've been using Room EQ Wizard for a little while and it has been very useful so far. I'm ...
Views: 852 - Replies: 4
Old 08-31-06, 04:17 AM   #1
ClementW
Inactive
Alias:
User: #
Posts: n/a
Hello,
I'm wandering if I can measure RT60 reverberation time with this software ? I noticed the impulse response window, but can I can use it for this purpose.
Thanks a lot.
Old 08-31-06, 08:44 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Reverberation time ?
The only reverb time decay graphs available in REW are the Low Frequency Spectral Decay graphs. RT60 is on the list to be added, but John says it has low priority and so may be a while. I don't know if he's included it in the next release...
Old 08-31-06, 09:19 AM   #3
ClementW
Inactive
Alias:
User: #
Posts: n/a
brucek wrote: View Post
Thanks a lot.
I suppose it should be possible to deduct the RT60 from the impulse response ?
Old 09-02-06, 06:13 PM   #4
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Yes, a clean impulse response is all you need to generate RT60 information (or any other information about the room's acoustics), but there is a reasonable amount of processing involved to get from the impulse to the RT60 data.
Old 09-03-06, 05:07 AM   #5
ClementW
Inactive
Alias:
User: #
Posts: n/a
JohnM wrote: View Post
I had no clue it involves extra processing. I was tempted to examine the impulse response curve and to find the time position where it falls 60dB... not as simple as that apparently... too bad
Thanks a lot! You made a really great program.
