Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
REW Forum
  Discuss first time user and not a wizard.... in the Equalization | Calibration forum; first time user and not a wizard.... I have attached the same in a LOG OK, those are all quite bad. Let's start from scratch. I'm sure ...
Views: 1217 - Replies: 50
Old 12-16-08, 01:44 PM   #11
Alias: brucek
User: #6
  brucek is offline
Re: first time user and not a wizard....
Let's start from scratch. I'm sure we can figure out the problem.
Can you post a pic of your settings page.....
Old 12-16-08, 01:57 PM   #12
Alias: jtwrace
Loc: NC
User: #8094
Since: Apr 2007
  jtwrace is offline
brucek wrote: View Post
the settings page...
Old 12-16-08, 02:14 PM   #13
Alias: brucek
User: #6
  brucek is offline
I'd like to see if the card is actually being recognized by REW.
Can you pull down the Output and Input Device Lists and actually select your card, and then select the line-out speaker and the line-in?
Here's an example of my Envy24 card with all the other correct settings. You can see once I select the cards that nothing is grayed out...
Old 12-16-08, 02:20 PM   #14
Alias: jtwrace
Loc: NC
User: #8094
Since: Apr 2007
  jtwrace is offline
yes, I can see all of that...how are you posting that page in the post?
Old 12-16-08, 02:40 PM   #15
Alias: brucek
User: #6
  brucek is offline
Can you show me the Settings page with all that set ?......
Place the mouse over the page of interest and select ALT plus PrtScr keyboard keys.
That copies the screen to the clipboard.
Start Windows Paint and Paste the clipboard to the app.
Save as a jpg of the correct size and post.
Old 12-16-08, 02:52 PM   #16
Alias: jtwrace
Loc: NC
User: #8094
Since: Apr 2007
  jtwrace is offline
try this
Old 12-16-08, 02:55 PM   #17
Alias: brucek
User: #6
  brucek is offline
Select Line-in and not Mic-in........
Also select 48Khz sample rate........
Old 12-16-08, 02:58 PM   #18
Alias: jtwrace
Loc: NC
User: #8094
Since: Apr 2007
  jtwrace is offline
there is not an option for line in...
Old 12-16-08, 03:22 PM   #19
Alias: brucek
User: #6
  brucek is offline
I suppose it must auto detect then.....
OK, all that seems fine then.
Let's carry on.
Tell me about the connection from line-out to line in that you're using to do the soundcard cal routine.
Do you have 1/8" stereo plugs that splits the right and left channels out, and then you connect a single cable from the line-out right to the line-in right?
Old 12-16-08, 03:28 PM   #20
Alias: jtwrace
Loc: NC
User: #8094
Since: Apr 2007
  jtwrace is offline
Let's carry on.
I'm using a Y 1/8" plug on one end and RCA (L&R) on the other. but I'm only using the R ch wire. It is a loop on the sound card.
time, user, wizard....
Bookmark and Share
Dish Network
