REW Forum
What am I doing wrong? (full sweep - no mic)
Discuss What am I doing wrong? (full sweep - no mic) in the Equalization | Calibration forum; What am I doing wrong? (full sweep - no mic) I'm trying to perform some output tests on my processor regarding x-over points and slopes. To remove all other components ...
Views: 339 - Replies: 5
Old 12-16-08, 07:12 PM   #1
Alias: TJ
User: #19303
Since: Apr 2008
  TJHUB is offline
I'm trying to perform some output tests on my processor regarding x-over points and slopes. To remove all other components from the readings (amp, speakers, etc), I have the line output of my processor connected directly to the input of my soundcard.
Here is the result:
I turned off the RS analog meter calibration file, so why the smiley face graph?
Thanks.
Old 12-16-08, 07:38 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: What am I doing wrong? (full sweep - no mic)
Uncheck the C-Weight box...............
Old 12-16-08, 07:43 PM   #3
Alias: TJ
User: #19303
Since: Apr 2008
  TJHUB is offline
brucek wrote: View Post
I knew that! I guess I was just in too much of a hurry. I got away from using REW for a few months. It's so easy to forget the little things.
I just received my Behringer ECM8000 today. That'll be my next adventure.
Bruce: Thanks for always being around here and helping like you. I really do appreciate the help you (and others) are always giving out.
Old 12-17-08, 09:04 AM   #4
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
I did the same thing years ago, only I had already gone through and set filters to correct and wondered why the bass sounded horrible. Then I ran the "empty" sweep and noticed the weighting. DOH!!!
Glad you got it fixed. For bass stuff, the Behringer is a great mic. What preamp are you using with it?
Old 12-17-08, 07:40 PM   #5
Alias: TJ
User: #19303
Since: Apr 2008
  TJHUB is offline
Anthony wrote: View Post
Actually I wasn't using a mic with that graph. I had my processor's line output going right into my sound card for the measurements I wanted.
I received my ECM8000 today. I just popped on the forum to get the setup instructions for the XENYX 802. I can't wait to get things working. Should be fun to play around with.
Old 12-18-08, 02:59 AM   #6
Alias: Tim
Loc: Redmond, WA
User: #13583
Since: Nov 2007
  hifisponge is offline
Hey TJ -
Just thought I'd pop in to say hello. I expect to see you over here from time to time when we aren't hanging out on AVS.
Cheers,
- Tim
(full, mic), sweep, wrong?
