REW 5.16 issues in OSX 10.11.5 - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 19 Old 06-29-16, 01:16 PM
REW Author
JohnM's Avatar
John
Re: REW 5.16 issues in OSX 10.11.5
Well I'm none the wiser really, null pointer exceptions where it shouldn't be possible for anything to be null. I can see where the feedback ripple effect comes from though, measuring with multiple sweeps requires data synchronisation to be maintained over the sequence of sweeps so if there is a hiccup in the data from the interface the alignment is lost and you end up with multiple peaks - the measurement you posted with two peaks suggests a single slip or gap in the data. That might also explain the occasional calibration failures as a gap can result in a buffer full of zeroes which would be clipped to -180 dBFS. Could try changing the buffer settings on REW's soundcard preferences, might help. Beyond that could try another interface, which admittedly would be a shame as that Apollo Twin looks like a great piece of kit.
JohnM is offline
post #12 of 19 Old 06-29-16, 01:41 PM Thread Starter
Chuck Zwicky
Very good insights, Thank you John. I work intimately with the manufacturer so perhaps I should bring up the possibility of a loss of synchronization. Any insights or advice from you in this matter would be most welcome.
zmix is offline
post #13 of 19 Old 06-29-16, 01:57 PM
REW Author
JohnM's Avatar
John
I wouldn't blame the interface, issues are more likely to lie between OS X and JavaSound.
JohnM is offline
post #14 of 19 Old 07-01-16, 02:46 PM
giordy60's Avatar
giordy60
zmix wrote: View Post
Even though I set the sweep to go from 1Hz to 24,000 Hz, the distortion plots all start at 10 Hz
hello zmix
that speakers use?
curious that starts to measure the sweep at 10hz.
giordy60 is offline
post #15 of 19 Old 07-03-16, 01:28 PM
Hi JohnM,
on REW 5.16 on OSX 10.11.5 I have another issue together with the one "Distortion plot is simply blank after taking a sweep measurement". After launching the program REW is asking for "Calibrate SPL". Once the calibration is made, if I close and re open the program REW is keep asking for the calibration. It doesn't store this setting.
Thanks.
Osho64 is offline
post #16 of 19 Old 07-03-16, 02:36 PM
REW Author
JohnM's Avatar
John
Hello Osho64, what are you using as the input to REW? What are the REW soundcard preferences set to?
JohnM is offline
post #17 of 19 Old 07-03-16, 05:10 PM
Hello John,
This are the settings for my Audio Interface, a Fast Track Pro from M-Audio.
Thank you.
Osho64 is offline
post #18 of 19 Old 07-04-16, 01:49 PM
REW Author
JohnM's Avatar
John
Thanks. I'm away on business until Friday, I'll investigate at the weekend.
JohnM is offline
post #19 of 19 Old 07-14-16, 03:05 PM
REW Author
JohnM's Avatar
John
Hi Osho64, please try 5.17 beta 6 to see if it fixes the lost calibration issue.
JohnM is offline
516 , issues , osx , rew
