Unable to measure FL+FR+subs after timing reference update - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 11 Old 07-11-16, 07:30 PM
Re: Unable to measure FL+FR+subs after timing reference update
JohnM wrote: View Post
The timing reference output selector shouldn't appear when not using a timing reference (it isn't being used for anything), it was being shown in error when the measurement dialog first opened but correctly hidden after that. I've fixed that for the next beta. It shouldn't make any difference to using the 2nd output channel though, and the second output channel should work fine whether or not a timing reference is being used. It seems to behave correctly when I test it with or without a timing reference.
Thanks John. Please note that I also experience this same behavior in 5.15 and 5.16 which I believe is prior to adding the drop down option in 5.17. So in those versions I am only able to measure one channel instead of two like the original post here references.
Also please note that when I use 5.17 beta 5 without the timing reference turned on and I just try to measure FL+FR (using the supplied drop down), the sub channel is acting very strange. It's like it is not getting a full sweep. When I choose sub only (channel 4), then the sub sounds normal. Although it could be something on my side, I do not experience this on version 5.13 and all of the settings are the same.
McLuvin is offline
fl , fr , measure , reference , subs , timing , unable , update
