SPL not working - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 07-24-16, 04:10 PM Thread Starter
Kennybugs
SPL not working
OK, I use the REW every few weeks and last time I used it about 2 weeks ago my mic and SPL sound pressure meter worked just fine. But now I can't get it to work. I use a UMIK-1 mic and it shows in preferences that is what I picked. I even tried to use the internal computer mic and it still won't work. The Generator works just fine going out to my speakers. I just use REW to measures the in room levels and then send the results to my miniDSP.
I reloaded both REW and Java and it still won't work. I did download ASIO and It seems to work, but I don't know how to use ASIO.
Could somebody help me out? I have a windows 10 laptop. It did work just fine but now won't.
Maybe somebody could tell me how to test my UMIK-1 mic to make sure it works.
Thank you for any help
Kenny
Kennybugs is offline
post #2 of 8 Old 07-24-16, 05:26 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: SPL not working
Not sure about Windows 10, but in 7 you open the “Sound” window click the “Recording” tab. The mic should appear as an option. Tapping on it should get you a signal on the level meter. If so, the mic should work in REW.
post #3 of 8 Old 07-24-16, 07:27 PM Thread Starter
Kennybugs
Re: SPL not working
Wayne, thank you as that did work. The mic was disabled.
But now I have another problem as the mic enables for a few seconds then disables again.
So it isn't in the REW program but something in windows 10 mic settings.
Again, thank you a lot for your help.
I'll Google this and see if I can find the problem.
Kenny
post #4 of 8 Old 07-24-16, 08:12 PM Thread Starter
Kennybugs
Re: SPL not working
I reloaded the driver for the sound card and the mic is staying up as long as I am in the mic settings but as soon as I exit and go back in it is disabled again. Will do some more looking to see if I can find the problem.
Kenny
post #5 of 8 Old 07-25-16, 07:45 AM
FargateOne's Avatar
Re: SPL not working
Kennybugs wrote: View Post
Kenny
I am not an expert, but the best way to learn about using Asio4All with hdmi, Umik-1 and rew is AustinJerry guide here:
https://dl.dropboxusercontent.com/u/...%20Version.pdf
Follow the instruction to the letter. I have win 10 on my laptop, it works; not easy for a dinausore like me but feasible !
FargateOne is offline
post #6 of 8 Old 07-25-16, 09:04 AM
Re: SPL not working
but as soon as I exit and go back in it is disabled again. but as soon as I exit and go back in it is disabled again.
Again in Windows 7 - once you select the mic, click the “Set [as] Default” button. Sounds like you’ll have to do the same thing with 10, too.
post #7 of 8 Old 07-25-16, 02:57 PM Thread Starter
Kennybugs
Re: SPL not working
It has OK, Cancel and Apply but the Apply won't hi lite for me to click. After awhile the mic mutes back out. Strange. If I hit OK it stays on for awhile then mutes back out.
I did get my measurements so I will keep at it until I figure it out.
Thanks FargateOne and Wayne.
Kenny
post #8 of 8 Old 07-29-16, 10:55 AM Thread Starter
Kennybugs
Re: SPL not working
Had a Malware on my computer. As soon as I got rid of the Malware my mic is not muting anymore.
Thanks for the help.
Kenny
spl , working
