Which place to choose among two for one sub only? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 07-25-16, 09:16 PM Thread Starter
FargateOne's Avatar
Hello,
In our home theater room, I can't change the furniture, nor the placement of the seats. I can't put any room treatment neither on walls nore on the ceiling. Guess why? Ok you know.
I am a molusk.
Now I can put my only sub ( no, I can't have a second one ) in 2 place only.
All the measurements are 1/6 smoothed.
Basically the left and the center speakers have the same response it is why I show center only. The Front right channel has the worst response.
I equed with REW manually
ASIDE THE FRONT RIGHT SPEAKER.
Here's the sub only
And the right and center fronts xo at 80:
Which place to choose among two for one sub only?-integration-right-front-eqed-sub-right-side.jpg
Which place to choose among two for one sub only?-integration-center-eqed-sub-right-side.jpg
ASIDE THE FRONT LEFT SPEAKER.
Here's the sub only
And the integration at xo 80
Which place to choose among two for one sub only?-integration-right-front-eqed-sub-left-side.jpg
Which place to choose among two for one sub only?-integration-center-eqed-sub-left-side.jpg
My brain says that the sub aside the right speaker is better but not my ears. The SS&I seems better if I put the sub at the side of the left speakers even with this abyssal dip around 58hz.
Any comments ?
FargateOne is offline
post #2 of 8 Old 07-25-16, 09:31 PM
Re: Which place to choose among two for one sub only?
Pretty graphs are nice and all, but when you get right down to it the sound is what matters. If you like it better on the left, place it on the left. If you can fix the dip at 58Hz with EQ/phase control/crossover adjustment, awesome... if you can live with it, just as well. If someone comes to your house, listens to your system, and then demands to see your REW graphs, politely ask them to leave.
DqMcClain is offline
post #3 of 8 Old 07-26-16, 07:41 AM Thread Starter
FargateOne's Avatar
DqMcClain wrote: View Post
(...) If you can fix the dip at 58Hz with EQ/phase control/crossover adjustment, awesome... if you can live with it, just as well.(...)
Yeah. I am not sure that I can live with this dip because it seems to be an important frequency. I do not know where to begin to improve this if it is even possible. No, I can't change the listening position. I already tweak the sub distance a little bit from 270cm to 315cm. I can't change the polarity of the sub but could change the polarity of the right speaker? Don't think this is a good idea. It remains the phase (0 to 180 degrees) ? Or again to play with the sub distance in the receiver? Or lower the crossover at 60 or 50hz?
post #4 of 8 Old 07-26-16, 09:23 AM
Todd Anderson
For the sub to the "right"... are you taking that measurement at the MLP? When listening are you sitting at the MLP?
When you say you don't like the sound... does it sound too boomy?
I would get external EQ...use REW...and attempt to dial-in the right position to my ear's liking.
Todd Anderson is offline
post #5 of 8 Old 07-26-16, 09:45 AM
Quenten
I would get a second sub & put them is each position & tell the wife you misunderstood ("honey you said there can only be subs in two spots...that's what I did, a sub in two spots!!!). Works every time!
Tonto is offline
post #6 of 8 Old 07-26-16, 02:37 PM Thread Starter
FargateOne's Avatar
Todd Anderson wrote: View Post
Yes all measurements to the MLP, the mic stays at the same place during the change of the sub position from the right to the left
HA! not easy to describe in english, let's say that whith the sub at the left, the sound stage "seems" to be more envelopping, fill the room better and that before EQ with the receiver filters.
Rotel as 10 adjustable filters for each channels (5 from 20 to 200hz and 5 from 1100 to 19 900hz) that I set with REW with quite not to bad results !
post #7 of 8 Old 07-26-16, 02:41 PM Thread Starter
FargateOne's Avatar
Tonto wrote: View Post
post #8 of 8 Old 08-01-16, 05:43 PM
Ah... "Sometimes forgiveness is easier than permission".
choose , place
