Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
Donations Reviews Vendors
MiniDSP: Digital audio Signal Processors (DSP) engineered to fit a wide range of applications.
Views: 1308 - Replies: 20
Old 12-31-08, 01:19 AM   #11
Silver Supporter
Bob
Since: Sep 2008
Oregon
My Photo Gallery
  hrpschrd is offline
I started this thread.
Re: Check Levels inconsistent??
Windows XP Professional
Old 12-31-08, 07:33 AM   #12
My Photo Gallery
  brucek is offline
Where do I find Windows Mixer?
Double click the speaker icon in your desktop system tray.
The two mixers are setup as below.
To select Recording, select options, then properties pulldown
Playback Mixer
Name:  Windows MIXER Playback.jpg
Record Mixer
Name:  Windows MIXER Record.jpg
Old 12-31-08, 11:27 AM   #13
Silver Supporter
Bob
Since: Sep 2008
Oregon
My Photo Gallery
  hrpschrd is offline
Thanks Bruce. Is this all I need to do or are the options Steven listed necessary also?
Also, besides checking the items do I need to adjust the levels just as you show them?
Old 12-31-08, 12:29 PM   #14
My Photo Gallery
  brucek is offline
Those options won't be available without the SB driver application software.
You set the levels as required by the Check Levels routine. I am only giving an example to show you what is enabled and muted.
Old 01-01-09, 11:39 AM   #15
Silver Supporter
Bob
Since: Sep 2008
Oregon
My Photo Gallery
  hrpschrd is offline
SUCCESS!
Thanks very much Brucek! I obviously didn't understand the necessity of adjusting the soundcard volume as well as input volume and preamp volume.
I am assuming that this graph is a correct one of course but I think I can now add a "room curve" adjustment to the bass. The treble doesn't roll off much to 20KHz but I like the sound in the room (which is heavily trapped). With the bass traps I have it looks like I don't have substantial peaks but I may not be able to reduce the troughs too much more. I think the waterfall is fairly good (not much beyond 300ms).
With a little help this software is really easy to use and it gives great results.
Old 01-01-09, 11:56 AM   #16
My Photo Gallery
  brucek is offline
Looks good.
Tips:
For subwoofers, always use the standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - 200Hz) using the Graph Limits button in the top right corner of REW.
For full range, use the standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - upper limits you desire, - certainly no higher than your soundcard or SPL meter can extend).
For full range only, enable smoothing to eliminate the comb filtering. Use a 1/3 octave smoothing.
The little floppy icon in the bottom left hand corner of your graph is used to save a jpg at 800 wide so you can post them here.
Old 12-01-09, 12:07 PM   #17
Silver Supporter
Bob
Since: Sep 2008
Oregon
My Photo Gallery
  hrpschrd is offline
Hello again a year later! And a year dummer: I am getting no sound during "Check Levels". I have read and re-read this thread but can't find the problem. It seems everything is setup the same as before with the same hardware.
To review: I have a SoundBlaster MP3 sound board connected to my stereo and my laptop. The Settings screen looks the same as before with the Mixer LineIn selected in Recording and muted in Playback. The "Check Level" output is at 0dB but Left and Right levels are not on scale. There is also NO sound.
What setting prevents output from the stereo (which is working fine)?
Old 12-01-09, 12:45 PM   #18
Silver Supporter
Bob
Since: Sep 2008
Oregon
My Photo Gallery
  hrpschrd is offline
Ok, found one mistake and am now getting -18dB in the Right channel but still no sound, so I cannot adjust to 75dB in the room. Arrgghhh.
Old 12-02-09, 01:31 PM   #19
Silver Supporter
Bob
Since: Sep 2008
Oregon
My Photo Gallery
  hrpschrd is offline
Just in case anyone reads this thread (brucek?), I have solved the problem but I have no idea how.
I know one has to set up the Windows Volume Control settings properly to send a signal. Although it should have no effect, I found that increasing the volume on the Playback/Wave brought my signal up and it stayed there even though I could turn it down and it wouldn't go away.
This was a case of just fiddling knobs and getting lucky. Any rhyme or reason to that?
Old 12-02-09, 01:49 PM   #20
Bill
Since: Sep 2009
Austin, TX
  laser188139 is offline
I did not mention it before, as the symptoms of the SoundBlaster card my wife's XP desktop computer were different. There, usually when I start REW I have sound, but no levels show in REW. When I go into Sound in Control Panel and switch from Line In to Mic and back to Line In, the REW now receives the audio and displays the levels. So it seems the SoundBlaster drivers are sometimes buggy, where they are not actually acting identically to the settings they display, but when you touch a control they recognize the new value and the behavior again matches the displayed state.
Bill
 Reply     Post New Thread     Back to Top of Page
check, inconsistent??, levels, moderator
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
