| REW Forum harmonics on impulse responseDiscuss harmonics on impulse response in the Equalization | Calibration forum; harmonics on impulse response Hey guys,I finally had access to a laptop again to take some new measurements and I noticed that this time ... |
Views: 393 - Replies: 21
| harmonics on impulse response Hey guys,I finally had access to a laptop again to take some new measurements and I noticed that this time around that I have 1st and 2nd order harmonic distortion on my impulse graphs that I did not have on previous measurements.Is the distortion higher in level than what would be considered normal?I used the same computer I used before and none of my equipment has changed other than eq settings.I'm actually using less eq than previously now that I've added additional treatment. Any Ideas on what might cause this? ![]() | ||||
| | #2 | |||||
| Re: harmonics on impulse response Quote:
brucek | |||||
| | #3 | ||||
| Re: harmonics on impulse response Actually when I was taking measurements REW's spl meter would briefly flash clip with some measurements but it would say[ levels ok 3dB headroom] so I don't know if that might have been the problem. The soundcard checks out fine. | ||||
| | #4 | |||||
Usually, until your sub is equalized, and you can take a measure that doesn't have large peaks that clip the SPL meter, I would ignore distortion. This is one of the problems of using an SPL meter for taking response measurements. A microphone (i.e. ECM8000) doesn't suffer from the constraint of having a limited range to work with before it clips the output. brucek | |||||
| | #6 | |||||
brucek | |||||
| | #7 | |||||
| Quote:
Posted via Mobile Device | |||||
| | #9 | ||||
| Re: harmonics on impulse response I thought the levels where the problem and I had checked the soundcard properly but I didn't ![]() ![]() When I perform the loopback test the left and right levels aren't equal only the right or the left (depending on which I use) level hits the proper level with the other being lower in level.I don't know if that's normal or not but I didn't have that problem when I originally calibrated the soundcard and then everything was fine no distortion. Here is what I get for the soundcard freq: ![]() Here is the impulse ![]() I didn't have this problem when I made my calibration file for my preamp and soundcard originally. | ||||
| | #10 | |||||
brucek | |||||
| | #11 | ||||
| Re: harmonics on impulse response What I meant to say is when I hook up the loopback I used just the right channels and the RMS/Peak meters for left and right are active but not at the same levels one is lower than the other. Just to check things I used the loopback for just the left channels and the same result only reversed with the left meter higher in level than the right. However both left and right meters are active no matter which single side left or right I use. | ||||
| | #14 | ||||
| Re: harmonics on impulse response Either you have an extreme amount of crosstalk or you have some effect turned on, or you have a fault. The unused channel should simply not be acting that way. brucek | ||||
| | #15 | ||||
| Re: harmonics on impulse response Make sure you are using the right kind of connectors to plug into your soundcard, if it has 1/8" sockets you need leads or adaptors with stereo 1/8" plugs, could get something like that plot if mono plugs were used. | ||||
| | #16 | ||||
| Re: harmonics on impulse response I don't know whats happened the mini plug to rca adapters are stereo.The soundcard is a internal laptop type and the settings are only simple wave and main volume settings along with left/right balance.Line level is selected and everything was as before.I never reperformed a soundcard calibration when I installed the latest version of REW but I don't think that is necessary correct?Well obviously I am already trying that know so that is mute. Prior to installing this latest version all my soundcard calibrations went off without a hitch and the file that automatically loads is correct. I am definitely puzzled by this. Should I reinstall the soundcard and REW programs? | ||||
| | #18 | ||||
| Re: harmonics on impulse response Well the good news is that I have fixed the problem with the meter ![]() I reinstalled the soundcard driver and BINGO! Now only the right meter is active and the calibration test went off without a hitch! Now the bad news It looks like I have more distortion than before![]() ![]() | ||||
| | #19 | ||||
| Re: harmonics on impulse response I would die to have a noise floor that was -105dBFS, and a couple harmonics that make it to -75dBFS......... You should revel in the lovely situation....... stop fussing.. ![]() | ||||
| | #20 | ||||
| Re: harmonics on impulse response That is just the soundcard impulse that is not an actual measurement. I thought if the soundcard measurement showed high distortion(what is normal) there was something wrong. If that is a good soundcard measurement than by all means I surely don't need to fuss As long as it's not my system and doesn't affect the actual measurements I'm good to go!I always like to double check and hear from knowledgeable people about things I'm not to sure about ![]() | ||||
| | #21 | |||||
All the other graphs are derived from the impulse response. brucek | |||||
