Best way to measure Multiple subs - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #1 of 12 Old 08-09-16, 01:59 PM Thread Starter
djnagle's Avatar
Hi All. I have 2 subwoofers in corner cabinets and the only good place to put them in my room is the front corners behind my main speakers. I'd like to figure out how much gain I am getting from them being in the corners. I have BASH 300 plate amps in each cabinets and I can add or reduce gain with a little soldering. Should I measure them with the mic 1 meter away from the driver or from my listening position? Cheers, Dennis.
cvai likes this.
djnagle is offline
post #2 of 12 Old 08-09-16, 02:59 PM
Blacklightning's Avatar
Re: Best way to measure Multiple subs
Always measure the room. Room gain and or corner placement is about the room creating more sound not the sub. Your sub will always play at the same level if you do not touch the dials but the sound in the room will change if you start moving things around.
Blacklightning is offline
post #3 of 12 Old 08-09-16, 04:16 PM Thread Starter
djnagle's Avatar
Thanks Black. Its good to be able to measure instead of doing it by ear.
djnagle is offline
post #4 of 12 Old 08-09-16, 04:28 PM
Measurement are always good but I must ask "why are you measuring this and what value are you going to compare this to?"
post #5 of 12 Old 08-09-16, 04:50 PM Thread Starter
djnagle's Avatar
I've built my system over the last many years and always tuned it by ear. Lately I've built bass traps and absorber panels so now I want to tweak it in proper.
djnagle is offline
post #6 of 12 Old 08-09-16, 04:55 PM Thread Starter
djnagle's Avatar
Also, I tri-amp with a DBX active crossover so I figured I would use all that adjustment to get it right.
djnagle is offline
post #7 of 12 Old 08-09-16, 05:01 PM
djnagle wrote: View Post
Hi All. I have 2 subwoofers in corner cabinets and the only good place to put them in my room is the front corners behind my main speakers. I'd like to figure out how much gain I am getting from them being in the corners. .
I've built my system over the last many years and always tuned it by ear. .
I see. Your first post led me to believe you were just wondering how much gain you get from corner placement. I now see that you are just trying to level match your system.
post #8 of 12 Old 08-09-16, 05:37 PM Thread Starter
djnagle's Avatar
I am just now finishing a preamp that will let me put my sub back in service so that is why I focus on the subs to begin with.
djnagle is offline
post #9 of 12 Old 08-10-16, 12:39 AM
You are a saucy man.
I'm working (slowly) on a pair of OB's bi-amped with with a dBX 223XL.
DqMcClain is offline
post #10 of 12 Old 08-10-16, 01:04 PM Thread Starter
djnagle's Avatar
Active is the way to go DQ. I have all the bits and pieces to build a Steve Bench tube crossover and when I get my system dialed in with the DBX, I'll build the tube crossover to those points.
Good luck with your OBs. I did a pair of those once using the 223XL. you won't be disappointed. D.
djnagle is offline
measure , multiple , subs
