| REW Forum first time userDiscuss first time user in the Equalization | Calibration forum; first time user Here is what I got after hooking everything up and running the software. Can someone tell me if this looks ... |
Views: 430 - Replies: 20
| first time user Here is what I got after hooking everything up and running the software. Can someone tell me if this looks correct? I want to buy a BFD if I am using this software correctly. See the graph below please. Last edited by golfman; 12-31-08 at 09:50 AM.. | ||||
| | #2 | |||||
| Re: first time user Quote:
Please post graphs instead of data... ![]() brucek | |||||
| | #3 | ||||
| Re: first time user I think I figured out how to post the graph to this site. Can someone tell me there thoughts on what I have here. I hooked the computer into my receiver through aux ran the subwoofer calibration tones and used a radio shack spl meter for a mic. My next question is going to be how can I test each of my speakers and do I need to buy the BFD to do that? I know to run filters and make changes I do, just not sure if I have to have it to test each speaker right now? Where do you buy the BFD online? Thanks ![]() Last edited by golfman; 12-31-08 at 09:55 AM.. | ||||
| | #4 | ||||||
Is it sub only or sub + mains? What is the crossover used - you haven't displayed the target line? Quote:
To test other than the mains and/or sub, generally people will feed REW into a left or right receiver AUX or CD input and then connect the appropriate speaker they want to test to that amplifier output, one at a time... brucek | ||||||
| | #5 | |||||
| Re: first time user Welcome to the Forum, golfman! Well, it’s not bad really. Your sub has great extension down to at least 20 Hz (you might want to extend the graph limits out to 10 Hz to see how low it really goes). Response between 90-20 Hz is in an 8 dB window. That’s unusually good for unequalized response. A BFD could make a noticeable improvement, but probably not a drastic improvement. The best improvement you’d probably get with it would be dialing in a house curve, if you feel you need one. Quote:
Regards, Wayne | |||||
| | #6 | ||||
| Re: first time user ]Sorry about that. The test was done with all speakers stereo, I hooked up to the receiver through the aux port. The sub crossover is 80hz. The receiver is an onkyo 706 and the audessy eq is enabled. I ran a new test with a target line and filters. I had some trouble with clipping. I tried several things but it still clips at the end. The headroom goes red and 0.0 db. Any help with level adjustments would be great. Can I just hook the computer to the sub directly and bypass the receiver, also do I have to unhook each speakers that I dont want to test from my receiver? ![]() Last edited by golfman; 12-31-08 at 12:12 PM.. | ||||
| | #7 | ||||||||
Please explain graph 1 with all the filters after the crossover used? If this is a sub only, why is the sub not tracking down the crossover on its own. It looks like the mains are still active? REW tip: there is a sort button on the filters popup to sort filters from 1 to 12.. brucek | ||||||||
| | #8 | ||||
| Re: first time user Where is the line in level located in the rew. I have just been turning down the speaker output on the computer? When I do this it effects my SPL Meter and it know longer is reading at 75 db. Is this correct? I will try to test again with just two channel stereo and the subs. All the speakers are still active in that graph. I will retest and post again. Thank you for all your help so far. | ||||
| | #9 | ||||
| Re: first time user Here is a new test I ran, I think I fixed some of my earlier problems with the test. This is stereo mains and the 2 subs. I lowered the midi input from this macbook so there is no more clipping on the test. I set my receiver to reference volume when I ran this test, so had to calibrate the SPL meter to 88db. I think this is correct. If I missed anything please advise. I ran filters and optimize the PK and Q. Please let me know what you think? ![]() | ||||
| | #10 | |||||||
When that's complete, run the Calibrate SPL routine and set to 75dB. Quote:
brucek | |||||||
| | #11 | ||||
| Re: first time user I ran the tests as you said here is the results. Also the audio midi properties is where I can control the macbook line in. ![]() This is the same test but with the audessy EQ built into the onkyo turned off. ![]() | ||||
| | #12 | ||||||
brucek | ||||||
| | #16 | |||||
The 2496 has slightly better specs, but not as much selection possibilities over the higher filters. It also doesn't have the multiple programs that the 1124 has. Either way, the BFD and FBQ are both fine.... brucek | |||||
| | #17 | ||||
| Re: first time user OK, thanks. Based off my graph it looks like I am getting bass all the way down to 15hz. Is that correct, or based off the lower SPL reading it won't be noticeable in movies? I am trying to download the .cal file for my RS meter but the files aren't pulling up for download. Any thoughts? Happy New Year to all. | ||||
| | #18 | |||||
Just click on the .cal file of choice and save it to a location of choice in your computer. Then point to it with REW... brucek | |||||
| | #19 | ||||
| Re: first time user Sorry about that, mac doesn't have a program to open it, so it looks like it didn't download to the computer. I checked my downloads and it did. I set it up in REW already. Thank you. I hate MAC, but its the only laptop we have that has a sound card to use the REW software. Any comments on my subs getting bass response down to 15hz. That seems good to me since I see other sub graphs on this site that don't look like their subs will play that low? | ||||
| | #20 | ||||
| Re: first time user When you make a measurement that includes your main speakers change the "speaker type" in the target settings to "full range", that will give you a flat line as the target - the target line which tracks the subwoofer crossover response is only for use when measuring the sub on its own. The output from the sub at 15Hz is down quite a bit, with your EQ turned on it is good down to just below 20Hz. | ||||
| | #21 | ||||
| Re: first time user Here is a graph with subs only, ![]() My response with subs only I guess goes down to about 20 hz at 75db. Looks like once the rew is put into place it should follow the target line pretty good. Last edited by golfman; 01-04-09 at 09:39 PM.. Reason: 2nd graph isn't correct, still has subwoofer target line | ||||
