Installation Problem - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 08-23-16, 05:29 AM Thread Starter
New Member
Exclamation Installation Problem
I'm trying to install on Windows 10, I've got JRE and JDK 1.8.0, JRE 64 and 32 bit, and JDK 64 bit, and even if I use the standalone distribution of this software, I get a error.log file created by the installer that says:
java.lang.NullPointerException
and then a bunch of functions with (Unknown Source) at the end.
What's up with that? That's for all three Windows releases. There's no way out. I even tried to install the x86 JRE to see if it was a x86/amd-64 issue, but apparently not...
Help?
poorandunlucky is offline
post #2 of 8 Old 08-26-16, 02:26 AM
REW Author
JohnM's Avatar
John
Re: Installation Problem
Can you attach the installer's error.log file?
JohnM is offline
post #3 of 8 Old 08-26-16, 03:28 AM Thread Starter
New Member
JohnM wrote: View Post
Code:
	at com.sun.java.swing.plaf.windows.XPStyle.getTypeEnumName(Unknown Source)
	at com.sun.java.swing.plaf.windows.XPStyle.getBorder(Unknown Source)
	at com.sun.java.swing.plaf.windows.WindowsLookAndFeel$XPBorderValue.getXPValue(Unknown Source)
	at com.sun.java.swing.plaf.windows.WindowsLookAndFeel$XPValue.createValue(Unknown Source)
	at javax.swing.UIDefaults.getFromHashtable(Unknown Source)
	at javax.swing.UIDefaults.get(Unknown Source)
	at javax.swing.MultiUIDefaults.get(Unknown Source)
	at javax.swing.UIDefaults.getBorder(Unknown Source)
	at javax.swing.UIManager.getBorder(Unknown Source)
	at javax.swing.border.TitledBorder.getBorder(Unknown Source)
	at javax.swing.border.TitledBorder.getBorderInsets(Unknown Source)
	at javax.swing.border.AbstractBorder.getBorderInsets(Unknown Source)
	at javax.swing.border.CompoundBorder.getBorderInsets(Unknown Source)
	at javax.swing.JComponent.getInsets(Unknown Source)
	at java.awt.GridBagLayout.GetMinSize(Unknown Source)
	at java.awt.GridBagLayout.getMinSize(Unknown Source)
	at java.awt.GridBagLayout.preferredLayoutSize(Unknown Source)
	at java.awt.Container.preferredSize(Unknown Source)
	at java.awt.Container.getPreferredSize(Unknown Source)
	at javax.swing.JComponent.getPreferredSize(Unknown Source)
	at java.awt.GridBagLayout.GetLayoutInfo(Unknown Source)
	at java.awt.GridBagLayout.getLayoutInfo(Unknown Source)
	at java.awt.GridBagLayout.ArrangeGrid(Unknown Source)
	at java.awt.GridBagLayout.arrangeGrid(Unknown Source)
	at java.awt.GridBagLayout.layoutContainer(Unknown Source)
	at java.awt.Container.layout(Unknown Source)
	at java.awt.Container.doLayout(Unknown Source)
	at java.awt.Container.validateTree(Unknown Source)
	at java.awt.Container.validate(Unknown Source)
	at java.awt.Container.validateUnconditionally(Unknown Source)
	at java.awt.Window.pack(Unknown Source)
	at com.install4j.runtime.wizard.WizardFrame.<init>(WizardFrame.java:17)
	at com.install4j.runtime.wizard.WizardBase.showFrame(WizardBase.java:41)
	at com.install4j.runtime.installer.frontend.WizardScreenExecutor.execute(WizardScreenExecutor.java:232)
	at com.install4j.runtime.installer.controller.Controller$1.run(Controller.java:136)
	at java.awt.event.InvocationEvent.dispatch(Unknown Source)
	at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
	at java.awt.EventQueue.access$500(Unknown Source)
	at java.awt.EventQueue$3.run(Unknown Source)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
	at java.awt.EventQueue.dispatchEvent(Unknown Source)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
	at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
	at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
	at java.awt.EventDispatchThread.run(Unknown Source)
	at java.awt.Window.dispatchEventImpl(Unknown Source)
	at java.awt.Component.dispatchEvent(Unknown Source)
	at java.awt.EventQueue$4.run(Unknown Source)
	at com.install4j.runtime.wizard.StandardScreen$1.componentResized(StandardScreen.java:178)
	at java.awt.Component.processComponentEvent(Unknown Source)
	at java.awt.Component.processEvent(Unknown Source)
	at java.awt.Container.processEvent(Unknown Source)
	at java.awt.Component.dispatchEventImpl(Unknown Source)
	at java.awt.Container.dispatchEventImpl(Unknown Source)
post #4 of 8 Old 08-26-16, 03:46 AM
REW Author
JohnM's Avatar
John
Are you running a custom look and feel or theme of some sort? Looks like the crash in inside the JRE, I've seen something like that a few years back when people were running something other than the standard LaF, though that was on XP.
JohnM is offline
post #5 of 8 Old 08-26-16, 11:35 AM Thread Starter
New Member
That's strange, how could a different look and feel affect the JRE, or your software? How could something crash inside the JRE when the JRE is bundled with it?
I always hated Java, and now I think it actually hates me...
post #6 of 8 Old 08-26-16, 01:09 PM
REW Author
JohnM's Avatar
John
It doesn't directly affect REW, but the JRE tries to use the native look and feel of the platform to render its windows, dialogs etc, if it encounters a theme that doesn't provide all the info a native theme provides it has problems. The installer is the one encountering the crash, it also uses Java.
JohnM is offline
post #7 of 8 Old 08-26-16, 02:45 PM Thread Starter
New Member
Oh, I see...
I have no issues with other Java software, though... I'm not sure if I have other Java software, though, but it's really the only thing that gives me trouble...
I think Inkscape is in Java, Blender might be, too... they both work fine...
post #8 of 8 Old 08-26-16, 04:13 PM
REW Author
JohnM's Avatar
John
Which REW version are you trying to install? Worth trying the latest beta, it may have a more recent installer than V5.16 (if that was what you were installing).
JohnM is offline
installation , problem
