REW 5.16 on Linux: Exception com.sun.media.sound.DirectAudioDevice cannot be cast to javax.sound.sampled.SourceDataLine - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 4 Old 08-24-16, 08:44 AM Thread Starter
New Member
REW 5.16 on Linux: Exception com.sun.media.sound.DirectAudioDevice$DirectClip cannot be cast to javax.sound.sampled.SourceDataLine
REW sometimes works for me if I choose actual audio-devices in preferences (best chances after rebooting and deleting REW config), otherwise it starts but audio output doesn't work: Checking Levels, Calibrating and measuring don't output any sound.
Choosing Pulse Audio Mixer as input and output-device has never worked - i require pulse audio because I have a 2.1-system with active speakers and pulse audio does lfe-crossover.
When output fails, the log contains the same every time:
Spoiler
Aug 24, 2016 2:32:21 PM roomeqwizard.RoomEQ_Wizard main
INFORMATION: REW V5,16 running JRE 1.8.0_91 64-bit on linux 4.4.0-34-generic
Exception in thread "AWT-EventQueue-0" java.lang.ClassCastException: com.sun.media.sound.DirectAudioDevice$DirectClip cannot be cast to javax.sound.sampled.SourceDataLine
at roomeqwizard.JD.B(Unknown Source)
at roomeqwizard.JD.k(Unknown Source)
at roomeqwizard.jC$13.actionPerformed(Unknown Source)
at javax.swing.JComboBox.fireActionEvent(JComboBox.java:1258)
at javax.swing.JComboBox.setSelectedItem(JComboBox.java:586)
at roomeqwizard.JD.A(Unknown Source)
at roomeqwizard.JD.C(Unknown Source)
at roomeqwizard.JD$1.actionPerformed(Unknown Source)
at javax.swing.Timer.fireActionPerformed(Timer.java:313)
at javax.swing.Timer$DoPostEvent.run(Timer.java:245)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivile ge(ProtectionDomain.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.jav a:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:1 16)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:1 09)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:184)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:229)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:227)
at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:227)
at java.awt.Dialog.show(Dialog.java:1084)
at javax.swing.JOptionPane.showOptionDialog(JOptionPane.java:869)
at roomeqwizard.RoomEQ_Wizard$3.run(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.jav a:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
der Papst is offline
post #2 of 4 Old 08-26-16, 03:23 AM
REW Author
JohnM's Avatar
John
Re: REW 5.16 on Linux: Exception com.sun.media.sound.DirectAudioDevice$DirectClip cannot be cast to javax.sound.sampled.SourceDataLine
Looks like a problem in the Pulse Audio mixer. REW is asking for a SourceDataLine but a DirectClip is being returned.
JohnM is offline
post #3 of 4 Old 08-26-16, 06:59 AM Thread Starter
New Member
JohnM wrote: View Post
Thanks for help
But why does output-device: USB or D2X sometimes work but most often not and pulseaudio-mixer never?
I've read java always uses pulseaudio unless set configured otherwise - i tried seting it to use alsa, doesn't work either (but i don't know if java really tried to use alsa or this post is just wrong)
And is this problem caused by pulseaudio or openjdk?
BTW: sry for my really bad english...
post #4 of 4 Old 08-26-16, 12:01 PM
REW Author
JohnM's Avatar
John
I'm afraid I don't know, sorry, but users have reported better results using Oracle's Java builds for Linux rather than OpenJDK.
JohnM is offline
516 , cast , exception , linux , rew
