ASIO benefits? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 09-07-16, 11:14 PM Thread Starter
ASIO benefits?
Hi please can someone tell me the benefits of using ASIO, other than it is easier to measure multiple channels
Thank you
Phillips is offline
post #2 of 8 Old 09-08-16, 12:18 AM
Wayne Myers
Re: ASIO benefits?
Phillips wrote: View Post
Thank you
ASIO bypasses all of the layers of audio-handling code that exist in different parts of the operating system (Windows) so that a more direct audio path exists, yielding low latency, important mainly in audio recording and mixing. I have herd, although I am not sure about this, that better (closer to) bit-perfect accuracy can be another benefit.
ASIO4ALL is a generic version of ASIO which makes it possible to have multiple devices accessible via a single driver interface, a capability not normally available with most sound card drivers.
AudiocRaver is offline
post #3 of 8 Old 09-08-16, 02:15 PM Thread Starter
Re: ASIO benefits?
Hi Wayne thank you
Do you know if ASIO drivers would be able to be used with a XTZ Pro 11 Mic?
Thanks again
Phillips is offline
post #4 of 8 Old 09-13-16, 06:15 AM
Wayne Myers
Re: ASIO benefits?
Hi Wayne thank you
Thanks again
The XTZ Pro II Mic uses generic Windows drivers, so it works fine with ASIO.
post #5 of 8 Old 09-13-16, 08:45 PM Thread Starter
Re: ASIO benefits?
AudiocRaver said: Oops, I accidentally messed up the OP's last post. So much for using the hone for posting.
I believe he asked:
Is the calibration for the XTZ mic 90 degree of 0 degree?
Phillips is offline
post #6 of 8 Old 09-13-16, 08:56 PM
Wayne Myers
Re: ASIO benefits?
90 degrees. So it can be used for a DRC or Dirac Live surround calibration.
Sorry about messing up your post.
post #7 of 8 Old 09-13-16, 10:49 PM Thread Starter
Re: ASIO benefits?
Hi Wayne no worries
Matter of interest do you have this mic?
If so do you miss it only being calibrated down to 20-20khz?
Does Dirac normally have a 90 degrees orientation?
Is it possible to calibrate the SPL with this mic?
Thank you for your time
Phillips is offline
post #8 of 8 Old 09-15-16, 06:03 AM
Wayne Myers
Re: ASIO benefits?
Hi Wayne no worriesri
My main mic is the BeyerDnamic MM-1. It comes with 0 degree calibration down to 60 Hz. I have extended the clibrationt down to 20 Hz using a calibrated UMIK-1 for reference. In general, being more interested in 2-channel / music listening, that is plenty low for me. Even looking at freuqencies lower than that, I am mainly looking for smoothness, so I am not too concerned over lower frequency accuracy.
Yes, any room correction app will use a 90 degree orientation mic.
Yes, as discussed in your other thread.
asio , benefits
