REW ForumDiscuss My Graph..Help with room speaker problems in the Equalization | Calibration forum; My Graph..Help with room speaker problems Hi Here is my graph for my sub (velo dps-12) and speaker (paradigm studio 20); both were taken as full ... |
Views: 798 - Replies: 3
| My Graph..Help with room speaker problems Hi Here is my graph for my sub (velo dps-12) and speaker (paradigm studio 20); both were taken as full range measurements (no xover) from my listening position... Do these look like room problems or speaker problems? Help ![]() Also does this software measure the THD at each freq? I didn't see that... Thanks! SD | ||||
| | #2 | ||||
| Re: My Graph..Help with room speaker problems First start with your sub only and the crossover set. Post the graph with a vertical axis from 45dB-105dB and a horizontal axis of 20hz-200Hz and show your target. Did you calibrate your soundcard and use the proper soundmeter calibration file? No, REW doesn't calculate THD. brucek | ||||
| | #3 | ||||
| Re: My Graph..Help with room speaker problems show which target? I didnt calibrate the sound card yet since I plan on using a different one for future tests but the dips are so extreme i think its beyond simply the sound card (how much beyond would be good to test) I did full range to figure out where to place the crossover...I can do it again..re THD what are the 2nd and 3rd harmonic in the left most pane of REW for then? Thanks! SD | ||||
| | #4 | |||||||
| Re: My Graph..Help with room speaker problems Quote:
The graph below shows a 75dB target with a SUB tab selected and the range I mentioned to use. ![]() Quote:
brucek | |||||||
