| REW Forum can't cal sound cardDiscuss can't cal sound card in the Equalization | Calibration forum; can't cal sound card here's the debug file.... |
Views: 395 - Replies: 19
| | #3 | ||||
| Re: cant cal sound card Anybody have an idea why I can't get the sound card calibrated???????I've uninstalled and reinstalled REW a couple of times and that doesn't make any diff, still no calibration line on the graph. | ||||
| | #4 | ||||
| Re: cant cal sound card Depends which line you are referring to. If you post a screenshot of the graph at the end of the cal that may give an idea what is going on, make sure the trace you want to see is selected (there is a tick in the box next to its name) and that the graph range is set correctly. | ||||
| | #7 | ||||
| Re: cant cal sound card Set the frequency axis to logarithmic by clicking the button third from right in the toolbar. In the graph legend what values do you see for the "Soundcard" trace after running through the "Measure" sequence from the soundcard settings? | ||||
| | #8 | ||||
| Re: cant cal sound card looks like the values are correct now but I still don't get anything after doing the measure sequence. Here's what it looks like after I go through the process, the only step I would have left is to "make cal", but because there is nothing there I can't do that..?? | ||||
| | #9 | ||||
| Re: cant cal sound card What values do you see for the "Soundcard" trace, i.e. as you move the cursor position on the graph what numbers are being shown in the legend for the trace labelled "Soundcard"? Please also post an image of the "Scope" tab after you have been through the Measure process. Were there any error or warning messages while stepping through the Measure process? | ||||
| | #10 | ||||
| Re: cant cal sound card here's the scope.....not sure exactly what you mean by "what numbers are being shown in the legend for the trace labelled SOUNDCARD"?? If I'm understanding you correctly....that is the problem I'm having, nothing is there (there is no soundcard trace) . Then again there's a fairly good chance I'm not fully understanding the question.....![]() | ||||
| | #11 | |||||
| Re: cant cal sound card Quote:
![]() brucek | |||||
| | #12 | ||||
| Re: cant cal sound card Those notes figures would be useful, but I meant the figures in the legend below the graph | ||||
| | #13 | ||||
| Re: cant cal sound card the ones john is looking for are all 0's...... the ones bruce was asking about are... sample rate--48000hz -3db points 0.0hz, 24000hz inpute device sb audygiy audio(c400) input--wave channel ---right input volume---.501 input rms target -12db actual rms at 1khz -16.1db output device----sb audygy audio (c400) output speaker sweep level -12db 20hz-20khz flatness +0.0,-0.0db | ||||
| | #14 | ||||
| Re: cant cal sound card The line is there, it is just perfectly flat at 0dB. The reason for that is you have WAVE selected as the input to the soundcard, so the output data is being fed straight back internally giving a perfectly flat line. Set the input to the Line In. | ||||
| | #16 | ||||
| Re: can't cal sound card Yes, looks OK. | ||||
| | #17 | ||||
| Re: can't cal sound card I figured out part of my problem....my sound card won't save the changes I am making (in the sound card inself) to get the sound card calibrated.....it won't let me "apply" the changes. So if I go out of rew is resets its self back to default(volume settings also). Any idea how to fix that?? Also the way I have it set up to work will not let me adjust the input volume(in rew), I have to goto the sound card itself and adjust the input vol and the wav vol to full and I adjust speaker vol to match the output on the meter.......is this correct?? You told me not to use "wave" but if I turn it off I loose all my signal, likewise if I turn off "input" I loose all my signal so I have been leaving them both on. Or maybe I am supposed to re cal. the sound card every when using REW. thanks for all the help.....rich | ||||
| | #18 | ||||
| Re: can't cal sound card On an Audigy (typically) Wave needs to be active to be available for the output, but your input should come from the signal called LINE_IN which is the "Analog Mix" from the soundcard, the line level is controlled from the soundcard's analog mix settings. I'm not clear what you mean by "turning off" wave or "input". You can make those selections with REW's input device and input selectors, or leave those as default and make the selections in your soundcard's control panel. The soundcard cal only needs to be done once and saved as a cal file, REW will automatically reload the cal file when it starts up. | ||||
| | #19 | ||||
| Re: can't cal sound card I know this is getting a little old but..... when exactly do I use the whole "left channel for reference"........just on the sound card cal----or just for measurements----- or never????? | ||||
| | #20 | |||||
| Re: can't cal sound card Quote:
brucek | |||||
