REW Forum
Two questions dumber than a noob....
Discuss Two questions dumber than a noob.... in the Equalization | Calibration forum; Two questions dumber than a noob.... These is probably a very dumb questions, but I at least need to ask it. I just recently bought myself ...
Views: 271 - Replies: 1
Old 01-04-09, 10:29 PM   #1
Alias: Eric
User: #20002
Since: Apr 2008
  eboettn is offline
These is probably a very dumb questions, but I at least need to ask it. I just recently bought myself a FBQ2496 to through on my B&W sub. (Merry Christmas to me!!) I've been messing around trying to learn REW and needed clarification.
When you adjust the trace offset (db) and add the offest to data, does it do anything to the actual EQ? I think the answer is no, but I wanted to make sure it doesn't boost or cut frequencies by moving that offset.
Finally, can somebody explain in a REW-for-Dummies type answer, what exactly the Target Level (db) is and what it does to the EQ filters.
Thanks everyone. I've learned a great deal on this forum (though I need to start posting more) and look forward to spending even more time reading it.
Happy New Year (a tad late)
Old 01-05-09, 08:33 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Two questions dumber than a noob....
eboettn wrote: View Post
Adjusting the offset has no direct effect on EQ, but it could change the filter recommendations (see next part).
The target curve shows the ideal response shape, it is the line the measurement would follow in a perfect world with no influence from the room, the sub/speaker characteristics etc. It acts as a reference for you and REW to use when looking at the measurement. When you use REW to make filter recommendations it sets up its filters to try and bring the measurement as close as possible to that target response. If the measurement is shifted (by using "add offset to data") that would move it relative to the target and so REW would suggest correspondingly different filter settings. Similarly if the level of the target response is changed that will alter the filter recommendations. Generally the target level is adjusted to bring it near to the middle of the measurement, so that the filter recommendations are used to compensate for the peaks in the measurement and not any overall level difference between target and measurement.
dumber, noob...., questions
