REW 5.17 help - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 2 Old 09-28-16, 11:13 AM Thread Starter
edincleve's Avatar
REW 5.17 help
It would be great if someone could help me with this:
My equipment consists of:
Windows 10 computer
Dayton Audio EMM-6 microphone
Focusrite Scarlett 2i2 audio interface.
I installed REW 5.17, and then upgraded to beta 10 when asked. Any of the tutorials I have read or watched use older versions or REW that look different on the Preferences page.
Question 1 - Under Drivers, do I use ASIO or Java?
Question 2 - How/When/Where do I enter the microphone calibration?
I have uploaded 2 screenshots with the Java driver selected, showing output devices and input devices that can be selected. Should I select Focusrite USB for the output, and if so, what input device do I select?
Thanks for any help you can give me.
Attached Files Java Outputs & Inputs selected.pdf (516.2 KB)
edincleve is offline
post #2 of 2 Old 10-01-16, 01:27 PM
REW Author
JohnM's Avatar
John
Re: REW 5.17 help
You can use ASIO or Java, for the Focusrite card may as well use Java unless you have a need for higher (than 48k) sample rates or sample resolution greater than 16 bits, those are only available using ASIO drivers (neither is needed for audio measurements). Focusrite USB is the correct device to select for output and input. You enter the mic cal file on the Mic/Meter tab, once you enter it REW will remember it for the next startup and load it automatically.
JohnM is offline
517 , rew
