REW V5.17 Beta 10 smoothing bug - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 3Likes
post #11 of 17 Old 10-02-16, 09:17 AM Thread Starter
Re: REW V5.17 Beta 10 smoothing bug
JohnM wrote: View Post
All the measurements in that file had a frequency dependent window, to remove it use the IR Windows dialog for each measurement and de-select it. Also check that frequency dependent window is not selected in the Impulse Response window defaults in the Analysis preferences.
Thanks John! That is indeed where the smoothing was being applied.
Let me ask, Was this global ( FDW smoothing ) a choice that I made in the past ?
Or is FDW now a default choice for every newly installed program ( my cleared Preferences not-withstanding ) ?
EarlK is offline
post #12 of 17 Old 10-02-16, 12:01 PM
REW Author
JohnM's Avatar
John
The default for FDW is off, so it looks like you must have selected FDW in the Analysis preferences at some point so it was applied for all new measurements from then.
JohnM is offline
post #13 of 17 Old 10-02-16, 12:35 PM Thread Starter
Thanks for that!
So why doesn't deleting preferences & shutting down the program, then uninstalling the program & rebooting the computer ( before re-installing the program ) not give me the expected behavior ( of no FDW being applied to any newly acquired file ) ?
Or put another way, why does an older local file preference get carried forward ( after everything above is executed ) to be effectively made into a ( an unseen ) global preference ( for all new captures ) ?
Or in other words; Why doesn't the "Preferences" window ( & all choices made within it ) reign supreme ?
EarlK is offline
post #14 of 17 Old 10-02-16, 01:49 PM
REW Author
JohnM's Avatar
John
Delete preferences and shut down works for me, a previous selection of applying FDW in Analysis preferences gets cleared (along with everything else being set back to defaults) and new measurements after REW is restarted don't have FDW applied. On Windows preferences are stored in the registry, delete preferences and shut down removes that registry key and all its contents. There is no other repository for the preferences.
JohnM is offline
post #15 of 17 Old 10-03-16, 04:38 PM Thread Starter
Thanks John for guiding me through the wilderness on this matter ( I've sent a donation your way ).
For those of us ( in our 60's and who are more likely ) to forget where we've been within the program you might consider adding a pop-up dialogue box ( when a user is in the Smoothing Menu ) challenging that "Remove Smoothing" is impossible due to FDW being in place.
- You could always offer the user the option ( then & there ) to disable FDW before granting the request to remove all smoothing.
Additionally, when FDW is enacted ( and a user chooses 1/48 smoothing / or other ) it would be handy to actually see FDW-1/48, FDW-1/24, FDW-1/12, etc. indicated within the lower legend ( there's obviously quite a visual difference of any FDW-1/xx smoothing versus regular 1/xx smoothing ) .
- That simple indicator would have most likely prevented this thread.
Thanks Again! <> EarlK
EarlK is offline
post #16 of 17 Old 10-03-16, 05:09 PM
REW Author
JohnM's Avatar
John
Although the FDW has an effect on the response that looks like smoothing, it is a form of variable windowing of the impulse response rather than a choice of smoothing - its effect is due to progressively narrowing the region of the impulse being analysed to steadily remove all but the direct response. The combination of removing the room's influence at higher frequencies (and so removing comb filtering) and the reduced frequency resolution of an ever narrower window combine to produce a response that looks smoothed, particularly at high frequencies. It doesn't really qualify as smoothing though. Having some indication when an FDW has been applied is a good idea nonetheless, I'll add that to the list and think about how it might best be done.
JohnM is offline
post #17 of 17 Old 10-22-16, 07:28 AM Thread Starter
Thanks John for adding the [ FDW ] notification in the Beta 11 release.
That is much appreciated!
EarlK is offline
10 , beta , bug , rew , smoothing , v517
