No Sound during Setting Levels???? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #11 of 47 Old 10-02-16, 06:51 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: No Sound during Setting Levels????
1. I have sound coming from my speakers
Excellent, now we’re getting somewhere.
2. Not sure what you have asked. In Output Device it says – Speakers (Realtek High Definition) -???
Is that the soundcard driving your speakers? If so all is good.
3. Again I have no idea what you have asked. I have in Control Panel in the PC under Sound/Recording/ UMIK-1 is ticked.
In the PC sound Recording Devices window, to you get a level on the meter when you tap on the head of the mic? If so all is good.
4. Input device – on the first line is: UMIK-1 Gain 18???
Good to see – as long as #3 is accomplished (i.e. the mic is sending signal to the computer), we’re in business.
post #12 of 47 Old 10-02-16, 07:00 PM Thread Starter
Hi Wayne
Thanks for the understanding and patience. It is very confusing.
I think the soundcard is driving the speakers. I get very confused with my set up. But I suppose it is??
The horizontal bars go up and down when I touch the UMK-1
So I think that is OK…..
I hope there is not too much more???ha-ha
Thank you.
Dan
foxint is offline
post #13 of 47 Old 10-03-16, 11:42 AM
It sounds like in your original post that have at least three sound cards - Realtek HD Audio, Little Dot DAC, and Raspberry Pi 3. Were interested in the one actually have you have your audio system connected to. It should show up in the Soundcard Output Devices drop-down box. If so, select it.
post #14 of 47 Old 10-03-16, 04:13 PM Thread Starter
Hi Wayne
Thank you
I only have one on-board sound. The rest are external.
Hope this helps
Talk soon???
foxint is offline
post #15 of 47 Old 10-03-16, 05:26 PM
If that’s the one your audio system is connected to, and it shows up in the Preferences / Soundcard window drop-down box. It looks like your mic works so you should be good to go. Just follow the directions in the Preferences / Soundcard window in the box for checking levels, then take a measurement.
post #16 of 47 Old 10-03-16, 05:52 PM Thread Starter
Hi Wayne
Thank you...
But what about the other boxes??
Which mic calibration file do I use? ????
Hi Wayne
Thank you….so you think it is OK…ha-ha…More confusion???
I was watching a Video -
I was confused with Calibration of the Soundcard…. but they said that was for later. But the next BUTTON was greyed out????
So I pushed Calibrate and I was able to move on – I wish there where detailed step-by-step
OK I pushed next a couple of time and got this noise. There are 3 vertical gauges only the Left Hand Side (LHS) showed anything – the video showed LHS and middle
The instructions said: The 1kHz tone is now playing. Adjust the Input Volume using the REW control (if enabled and available) or your soundcard's mixer or your OS audio level controls so that the input level is close to the output level, ideally within 6dB, and the peak level (the red line on the bar) is lower than -1dB.
HOW do I do this?
The noise is bloody annoying – so lucky I have some ear muffs….ha-ha.
Every time I turn it off, it goes back to the first page of the preference and I have to hit calibrate again… I am sure this is not right??
Thank You
Dan
foxint is offline
post #17 of 47 Old 10-03-16, 06:40 PM
The mic should have come with a calibration file. You don't want to use any other one.
post #18 of 47 Old 10-03-16, 07:18 PM Thread Starter
Hi Wayne
Thank you
This is a total nightmare and you need to be some sort of sound engineer????
For the mike I have - 7018961.txt or 7018961_90deg.txt. I chose 7018961 -??
As per my questions above….it is certainly not plug and play.
Any suggestions??? Help
foxint is offline
post #19 of 47 Old 10-03-16, 07:44 PM
7018961.txt is for taking measurements with the mic pointed directly at the speaker. 7018961_90deg.txt should be used if you want to take measurements with the mic pointing straight up. In most situation, unless your room has a highly reflective ceiling, either method gets satisfactory results.
post #20 of 47 Old 10-03-16, 08:25 PM Thread Starter
Hi Wayne
Thank you. I will use the one with the shorter name.
I am now stuck on the next step....as I noted above.
The noise happens and the LHS bar shows a level, but there is no level on either of the other 2. How does one proceed?
From what I understand (and I may be wrong) there needs to be something in the other two things.
Thanks
Dan
foxint is offline
levels , setting , sound
