No Sound during Setting Levels???? - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #1 of 47 Old 10-01-16, 05:11 PM Thread Starter
Hi Guys
Great forum. I have been lurking for some time, but not really posted/replied as I really do not have the knowledge to make any meaningful contributions.
But I am stuck…. I bought the minidsp UMIK-1
I followed the UMIK-1 setup with REW - below
https://www.minidsp.com/applications...setup-with-rew
I read the
REW Cabling and Connection Basics
Plus, many other things… but I have no noise.
When I get to 4. Set Levels – no noise?
I asked minidsp and they told me here…so here I am.
My gut feeling is it is my media/sound setting on my PC – that I have no idea about.
System:
PC – Win 10 Pro 64 bit
Realtek HD Audio
Little Dot DAC
Little Dot CD Transport
Various Pro-Audio stuff
Plus, I have Raspberry Pi 3 with DigiPlus – very good and very cheap
I connected the UMIK-1 to the PC with the USB supplied
I connected the green hole that says Speaker Out (there is an optical out – but that is connected to my DAC) with 3.5mm plug that terminates in 2 XLR to my pre-amp
There are so many audio setting on the PC that are not covered
And no sound. So I have not even got past the initial steps. I am looking forward to using this excellent software, but after 4 weeks I am stuff and beaten
Can any nice person help??? I am a real novice….so please be kind and I do need it spelt out
foxint is offline
post #2 of 47 Old 10-01-16, 07:21 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: No Sound during Setting Levels????
Both the Speaker Out jack and your 3.5mm cable must be TRS. If one of them is TS, then it isn’t going to work.
In the operating system Sound / Playback Devices tab, select the option that your cable is plugged in to and set it as Default. Also set the UMIK-1 as the default Recording Device.
The same devices will be selected in REW’s Preferences / Soundcard tab.
post #3 of 47 Old 10-01-16, 08:34 PM Thread Starter
Hi Wayne
Before we go too far....
Can you explain what TRS is??
Are there instructions to set up the preferences..... I have no idea what all these things are?? Drivers for example - ??????
D
foxint is offline
post #4 of 47 Old 10-01-16, 09:17 PM Thread Starter
Hi
I am reading more and getting more confused.
Still no noise.
Not sure what TRS is….
But let's look at the preferences:
• Drivers – Java or ASIO – I downloaded ASIO a while ago, but I do not know what it is and not sure if it works
• Output Device – Default or Primary Sound Driver or Realtek Digital Output (Optical) or Speakers (Realtek High Definition) or Speakers (Plantronics D100) or Realtek Digital Output (Realtek)
• Buffer – what number
• Input Device – I am assuming UMIK1 as it defaulted???
For the Mike UMIK-1 it asked for a calibration file which one?:
• 7018961.txt or
• 7018961_90deg.txt
I guessed the 7018961???
Then next line is a little less stuff:
• Sample Rate – 48kHz or 44.1kHx
• Output is greyed out – so I am assuming it is good
• Buffer is greyed out – so I am assuming it is good
• Input – Microphone (Master …) or default input
• Buffer – Right or left.
Perhaps I will leave the rest….
Sorry, but this is completely confusing????
foxint is offline
post #5 of 47 Old 10-01-16, 11:43 PM
willis7469's Avatar
Sent from my iPhone using Tapatalk
willis7469 is online now
post #6 of 47 Old 10-02-16, 03:03 AM Thread Starter
Sir
Thank you. I have a TRS...so that is one thing out of the way.
I still have no noise?
Can anyone help???
foxint is offline
post #7 of 47 Old 10-02-16, 06:58 AM
Hi
Still no noise.
• 7018961.txt or
• 7018961_90deg.txt
Please, you’re running ahead of yourself. Let’s deal with one thing at a time - we haven’t even solved the original issue yet.
First let’s make sure you’re getting sound to your audio system. So play a music file or some other kind of audio from your computer and make sure it’s playing through your stereo. We can’t go any further until you verify this: If you can’t play audio from your computer, then any signals REW generates aren’t going to come through either.
If you aren’t getting anything from the computer to the system, go to the computer’s operating system Sound / Playback [devices] tab and make sure the correct playback device is selected. I can’t tell for sure, it looks like you have a lot of playback hardware – Reaktek, Little Dot, Raspberry. We’re looking for the one that you have connected to your audio system. If you have audio playing on your computer you should see a reading on the meter next to one of the selections. Set that one as the Default device.
Once you get that lined out we can make sure your UMIK-1 is going to work. Again in the operating system Sound window, select the Recording [devices] tab. The UMIK-1 should be an option. Tap on the head of the mic and you should see a reading on the meter. Set the UMIK-1 as the default Recording Device.
Now you should be able to open the Preferences / Soundcard window in REW and see your playback device and the UMIK-1 in the “Input Device” and Output Device” drop down boxes. Select the appropriate options in each drop-down.
We can’t go any further until you can successfully get to this point: The operating system has to be set up properly as far as recording and playback devices are concerned, with those devices showing up as options in REW’s “Input Device” and Output Device” drop down boxes.
Please report back when you’ve accomplished this.
post #8 of 47 Old 10-02-16, 04:40 PM Thread Starter
Hi Wayne
Thank you. You have been great. Yes I have a lot of stuff and it was very hard to get it all working.....The equipment is good enough for us to use the best setting
SORRY - all the formatting disappeared???
Just as an aside, all I want to do is run some frequency tests and equalise my room and speakers. (Yes I have an electronic crossover and an equaliser as well as an Aphex).
Just got to get enough in this post as the time zones are against me – I am in rural Australia
I can play music from:
• Optical out to DAC from either my PC or my DAC
• I am assuming it is the 3.5mm stereo plug that is the pathway???
Let’s go:
• I have plugged in the 3.5mm plug
• Set the PC Sound default to Speakers
• Set Pre-amp to PC Speaker out
• Control Panel – Trouble Shoot Audio Playback – I get noise…. yippee
• Control Panel – UMIK-1 has a tick on the recording
Open REW
• It asks for the calibration code. - 7018961.txt or 7018961_90deg.txt. I chose 7018961 -??
“Now you should be able to open the Preferences / Soundcard window in REW and see your playback device and the UMIK-1 in the “Input Device” and Output Device” drop down boxes. Select the appropriate options in each drop-down.”
There are 2 lines that say almost the same??
Line 1:
Drivers Output Device Buffer Input Buffer
Java or ASIO Default or Primary Sound Driver or UMIK-1
Speakers (Realtek High Definition) or I am assuming this????
Still have no idea what Buffer is. What number?
Line 2:
Sample Rate Output Buffer Input Buffer
48kHz or Default or Left Default Input Right
44.1kHx Speakers Right Microphone (Master) Left
Both - ?? this one
Input Options Control input mixer/volume – ticked??
Invert ??? “Greyed Out” Input Volume 0.?????
High Pass???
Calibration
File None?? Browse “Greyed Out” Calibrate Make Cal
Levels
Use subwoofer test signal to check/set levels or Check Levels Generate Debug File
Use main speaker test signal to check/set levels
Thanks again for all your help. It is a pity they do not right a manual for novices
foxint is offline
post #9 of 47 Old 10-02-16, 05:50 PM
Honestly, too much information. Please just verify that:
  1. That you have audio playing from your speakers.
  2. That the sound card that’s playing the speakers is appearing in the REW Preferences / Soundcard “Output Device” drop down box (I don’t care about the others).
  3. That you have signal from the mic in the PC Recording Devices window, and it’s set as the Default.
  4. That the UMIK-1 is appearing in the REW Preferences / Soundcard “Input Device” drop down box.
I will make no further replies until you verify the above. That’s all I need at this point, nothing else. We have to get past this before we can go any further.
post #10 of 47 Old 10-02-16, 06:26 PM Thread Starter
Hi Wayne
Thanks again:
1. I have sound coming from my speakers
2. Not sure what you have asked. In Output Device it says – Speakers (Realtek High Definition) -???
3. Again I have no idea what you have asked. I have in Control Panel in the PC under Sound/Recording/ UMIK-1 is ticked.
4. Input device – on the first line is: UMIK-1 Gain 18???
Is this OK??
foxint is offline
levels , setting , sound
